Dataset-to-model Traceability with NetApp and MLflow
Contributors kevin-hoke
The NetApp DataOps Toolkit for Kubernetes can be used in conjunction with MLflow's experiment tracking capabilities in order to implement dataset-to-model or workspace-to-model traceability.
To implement dataset-to-model or workspace-to-model traceability, simply create a snapshot of your dataset or workspace volume using the DataOps Toolkit as part of your training run, as shown the following example code snippet. This code will save the data volume name and snapshot name as tags associated with the specific training run that you are logging to your MLflow experiment tracking server.
from netapp_dataops.k8s import create_volume_snapshot
with mlflow.start_run() :
    namespace = "my_namespace" # Kubernetes namespace in which dataset volume PVC resides
    dataset_volume_name = "project1" # Name of PVC corresponding to dataset volume
    snapshot_name = "run1" # Name to assign to your new snapshot
    # Create snapshot
    create_volume_snapshot(
        namespace=namespace,
        pvc_name=dataset_volume_name,
        snapshot_name=snapshot_name,
        printOutput=True
    # Log data volume name and snapshot name as "tags"
    # associated with this training run in mlflow.
    mlflow.set_tag("data_volume_name", dataset_volume_name)
    mlflow.set_tag("snapshot_name", snapshot_name)
