Milvus with Amazon FSx ONTAP for NetApp ONTAP - file and object duality
This section discusses the milvus cluster setup with Amazon FSx ONTAP for the vector database solution for NetApp.
Milvus with Amazon FSx ONTAP for NetApp ONTAP – file and object duality
In this section, Why we need to deploy vector database in cloud as well as steps to deploy vector database ( milvus standalone) in Amazon FSx ONTAP for NetApp ONTAP within docker containers.
Deploying a vector database in the cloud provides several significant benefits, particularly for applications that require handling high-dimensional data and executing similarity searches. First, cloud-based deployment offers scalability, allowing for the easy adjustment of resources to match the growing data volumes and query loads. This ensures that the database can efficiently handle increased demand while maintaining high performance. Second, cloud deployment provides high availability and disaster recovery, as data can be replicated across different geographical locations, minimizing the risk of data loss, and ensuring continuous service even during unexpected events. Third, it provides cost-effectiveness, as you only pay for the resources you use, and can scale up or down based on demand, avoiding the need for substantial upfront investment in hardware. Finally, deploying a vector database in the cloud can enhance collaboration, as data can be accessed and shared from anywhere, facilitating team-based work and data-driven decision making.
Please check the architecture of the milvus standalone with Amazon FSx ONTAP for NetApp ONTAP used in this validation.
Create an Amazon FSx ONTAP for NetApp ONTAP instance and note down the details of the VPC, VPC security groups, and subnet. This information will be required when creating an EC2 instance. You can find more details here - https://us-east-1.console.aws.amazon.com/fsx/home?region=us-east-1#file-system-create
Create an EC2 instance, ensuring that the VPC, Security Groups, and subnet match those of the Amazon FSx ONTAP for NetApp ONTAP instance.
Install nfs-common using the command 'apt-get install nfs-common' and update the package information using 'sudo apt-get update'.
Create a mount folder and mount the Amazon FSx ONTAP for NetApp ONTAP on it.
ubuntu@ip-172-31-29-98:~$ mkdir /home/ubuntu/milvusvectordb ubuntu@ip-172-31-29-98:~$ sudo mount 172.31.255.228:/vol1 /home/ubuntu/milvusvectordb ubuntu@ip-172-31-29-98:~$ df -h /home/ubuntu/milvusvectordb Filesystem Size Used Avail Use% Mounted on 172.31.255.228:/vol1 973G 126G 848G 13% /home/ubuntu/milvusvectordb ubuntu@ip-172-31-29-98:~$
Install Docker and Docker Compose using 'apt-get install'.
Set up a Milvus cluster based on the docker-compose.yaml file, which can be downloaded from the Milvus website.
root@ip-172-31-22-245:~# wget https://github.com/milvus-io/milvus/releases/download/v2.0.2/milvus-standalone-docker-compose.yml -O docker-compose.yml --2024-04-01 14:52:23-- https://github.com/milvus-io/milvus/releases/download/v2.0.2/milvus-standalone-docker-compose.yml <removed some output to save page space>
In the 'volumes' section of the docker-compose.yml file, map the NetApp NFS mount point to the corresponding Milvus container path, specifically in etcd, minio, and standalone.Check Appendix D: docker-compose.yml for details about changes in yml
Verify the mounted folders and files.
ubuntu@ip-172-31-29-98:~/milvusvectordb$ ls -ltrh /home/ubuntu/milvusvectordb total 8.0K -rw-r--r-- 1 root root 1.8K Apr 2 16:35 s3_access.py drwxrwxrwx 2 root root 4.0K Apr 4 20:19 volumes ubuntu@ip-172-31-29-98:~/milvusvectordb$ ls -ltrh /home/ubuntu/milvusvectordb/volumes/ total 0 ubuntu@ip-172-31-29-98:~/milvusvectordb$ cd ubuntu@ip-172-31-29-98:~$ ls docker-compose.yml docker-compose.yml~ milvus.yaml milvusvectordb vectordbvol1 ubuntu@ip-172-31-29-98:~$ -
Run 'docker-compose up -d' from the directory containing the docker-compose.yml file.
Check the status of the Milvus container.
ubuntu@ip-172-31-29-98:~$ sudo docker-compose ps Name Command State Ports ---------------------------------------------------------------------------------------------------------------------------------------------------------- milvus-etcd etcd -advertise-client-url ... Up (healthy) 2379/tcp, 2380/tcp milvus-minio /usr/bin/docker-entrypoint ... Up (healthy) 0.0.0.0:9000->9000/tcp,:::9000->9000/tcp, 0.0.0.0:9001->9001/tcp,:::9001->9001/tcp milvus-standalone /tini -- milvus run standalone Up (healthy) 0.0.0.0:19530->19530/tcp,:::19530->19530/tcp, 0.0.0.0:9091->9091/tcp,:::9091->9091/tcp ubuntu@ip-172-31-29-98:~$ ubuntu@ip-172-31-29-98:~$ ls -ltrh /home/ubuntu/milvusvectordb/volumes/ total 12K drwxr-xr-x 3 root root 4.0K Apr 4 20:21 etcd drwxr-xr-x 4 root root 4.0K Apr 4 20:21 minio drwxr-xr-x 5 root root 4.0K Apr 4 20:21 milvus ubuntu@ip-172-31-29-98:~$ -
To validate the read and write functionality of vector database and it's data in Amazon FSx ONTAP for NetApp ONTAP, we used the Python Milvus SDK and a sample program from PyMilvus. Install the necessary packages using 'apt-get install python3-numpy python3-pip' and install PyMilvus using 'pip3 install pymilvus'.
Validate data writing and reading operations from Amazon FSx ONTAP for NetApp ONTAP in the vector database.
root@ip-172-31-29-98:~/pymilvus/examples# python3 prepare_data_netapp_new.py === start connecting to Milvus === === Milvus host: localhost === Does collection hello_milvus_ntapnew_sc exist in Milvus: True === Drop collection - hello_milvus_ntapnew_sc === === Drop collection - hello_milvus_ntapnew_sc2 === === Create collection `hello_milvus_ntapnew_sc` === === Start inserting entities === Number of entities in hello_milvus_ntapnew_sc: 9000 root@ip-172-31-29-98:~/pymilvus/examples# find /home/ubuntu/milvusvectordb/ … <removed content to save page space > … /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/103/448789845791411923/b3def25f-c117-4fba-8256-96cb7557cd6c /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/103/448789845791411923/b3def25f-c117-4fba-8256-96cb7557cd6c/part.1 /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/103/448789845791411923/xl.meta /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/0 /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/0/448789845791411924 /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/0/448789845791411924/xl.meta /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/1 /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/1/448789845791411925 /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/1/448789845791411925/xl.meta /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/100 /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/100/448789845791411920 /home/ubuntu/milvusvectordb/volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/100/448789845791411920/xl.meta -
Check the reading operation using the verify_data_netapp.py script.
root@ip-172-31-29-98:~/pymilvus/examples# python3 verify_data_netapp.py === start connecting to Milvus === === Milvus host: localhost === Does collection hello_milvus_ntapnew_sc exist in Milvus: True {'auto_id': False, 'description': 'hello_milvus_ntapnew_sc', 'fields': [{'name': 'pk', 'description': '', 'type': <DataType.INT64: 5>, 'is_primary': True, 'auto_id': False}, {'name': 'random', 'description': '', 'type': <DataType.DOUBLE: 11>}, {'name': 'var', 'description': '', 'type': <DataType.VARCHAR: 21>, 'params': {'max_length': 65535}}, {'name': 'embeddings', 'description': '', 'type': <DataType.FLOAT_VECTOR: 101>, 'params': {'dim': 8}}], 'enable_dynamic_field': False} Number of entities in Milvus: hello_milvus_ntapnew_sc : 9000 === Start Creating index IVF_FLAT === === Start loading === === Start searching based on vector similarity === hit: id: 2248, distance: 0.0, entity: {'random': 0.2777646777746381}, random field: 0.2777646777746381 hit: id: 4837, distance: 0.07805602252483368, entity: {'random': 0.6451650959930306}, random field: 0.6451650959930306 hit: id: 7172, distance: 0.07954417169094086, entity: {'random': 0.6141351712303128}, random field: 0.6141351712303128 hit: id: 2249, distance: 0.0, entity: {'random': 0.7434908973629817}, random field: 0.7434908973629817 hit: id: 830, distance: 0.05628090724349022, entity: {'random': 0.8544487225667627}, random field: 0.8544487225667627 hit: id: 8562, distance: 0.07971227169036865, entity: {'random': 0.4464554280115878}, random field: 0.4464554280115878 search latency = 0.1266s === Start querying with `random > 0.5` === query result: -{'random': 0.6378742006852851, 'embeddings': [0.3017092, 0.74452263, 0.8009826, 0.4927033, 0.12762444, 0.29869467, 0.52859956, 0.23734547], 'pk': 0} search latency = 0.3294s === Start hybrid searching with `random > 0.5` === hit: id: 4837, distance: 0.07805602252483368, entity: {'random': 0.6451650959930306}, random field: 0.6451650959930306 hit: id: 7172, distance: 0.07954417169094086, entity: {'random': 0.6141351712303128}, random field: 0.6141351712303128 hit: id: 515, distance: 0.09590047597885132, entity: {'random': 0.8013175797590888}, random field: 0.8013175797590888 hit: id: 2249, distance: 0.0, entity: {'random': 0.7434908973629817}, random field: 0.7434908973629817 hit: id: 830, distance: 0.05628090724349022, entity: {'random': 0.8544487225667627}, random field: 0.8544487225667627 hit: id: 1627, distance: 0.08096684515476227, entity: {'random': 0.9302397069516164}, random field: 0.9302397069516164 search latency = 0.2674s Does collection hello_milvus_ntapnew_sc2 exist in Milvus: True {'auto_id': True, 'description': 'hello_milvus_ntapnew_sc2', 'fields': [{'name': 'pk', 'description': '', 'type': <DataType.INT64: 5>, 'is_primary': True, 'auto_id': True}, {'name': 'random', 'description': '', 'type': <DataType.DOUBLE: 11>}, {'name': 'var', 'description': '', 'type': <DataType.VARCHAR: 21>, 'params': {'max_length': 65535}}, {'name': 'embeddings', 'description': '', 'type': <DataType.FLOAT_VECTOR: 101>, 'params': {'dim': 8}}], 'enable_dynamic_field': False} -
If the customer wants to access (read) NFS data tested in the vector database via the S3 protocol for AI workloads, this can be validated using a straightforward Python program. An example of this could be a similarity search of images from another application as mentioned in the picture that is in the beginning of this section.
root@ip-172-31-29-98:~/pymilvus/examples# sudo python3 /home/ubuntu/milvusvectordb/s3_access.py -i 172.31.255.228 --bucket milvusnasvol --access-key PY6UF318996I86NBYNDD --secret-key hoPctr9aD88c1j0SkIYZ2uPa03vlbqKA0c5feK6F OBJECTS in the bucket milvusnasvol are : *************************************** … <output content removed to save page space> … bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611920/0/448789845791411917/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611920/1/448789845791411918/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611920/100/448789845791411913/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611920/101/448789845791411914/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611920/102/448789845791411915/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611920/103/448789845791411916/1c48ab6e-1546-4503-9084-28c629216c33/part.1 volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611920/103/448789845791411916/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/0/448789845791411924/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/1/448789845791411925/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/100/448789845791411920/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/101/448789845791411921/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/102/448789845791411922/xl.meta volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/103/448789845791411923/b3def25f-c117-4fba-8256-96cb7557cd6c/part.1 volumes/minio/a-bucket/files/insert_log/448789845791611912/448789845791611913/448789845791611939/103/448789845791411923/xl.meta volumes/minio/a-bucket/files/stats_log/448789845791211880/448789845791211881/448789845791411889/100/1/xl.meta volumes/minio/a-bucket/files/stats_log/448789845791211880/448789845791211881/448789845791411889/100/448789845791411912/xl.meta volumes/minio/a-bucket/files/stats_log/448789845791611912/448789845791611913/448789845791611920/100/1/xl.meta volumes/minio/a-bucket/files/stats_log/448789845791611912/448789845791611913/448789845791611920/100/448789845791411919/xl.meta volumes/minio/a-bucket/files/stats_log/448789845791611912/448789845791611913/448789845791611939/100/1/xl.meta volumes/minio/a-bucket/files/stats_log/448789845791611912/448789845791611913/448789845791611939/100/448789845791411926/xl.meta *************************************** root@ip-172-31-29-98:~/pymilvus/examples#This section effectively demonstrates how customers can deploy and operate a standalone Milvus setup within Docker containers, utilizing Amazon's NetApp FSx ONTAP for NetApp ONTAP data storage. This setup allows customers to leverage the power of vector databases for handling high-dimensional data and executing complex queries, all within the scalable and efficient environment of Docker containers. By creating an Amazon FSx ONTAP for NetApp ONTAP instance and matching EC2 instance, customers can ensure optimal resource utilization and data management. The successful validation of data writing and reading operations from FSx ONTAP in the vector database provides customers with the assurance of reliable and consistent data operations. Additionally, the ability to list (read) data from AI workloads via the S3 protocol offers enhanced data accessibility. This comprehensive process, therefore, provides customers with a robust and efficient solution for managing their large-scale data operations, leveraging the capabilities of Amazon's FSx ONTAP for NetApp ONTAP.
