NetApp container solutions
Red Hat OpenShift Service on AWS with NetApp ONTAP
Contributors banum-netapp kevin-hoke
Overview
In this section, we will show how to utilize FSx for ONTAP as a persistent storage layer for applications running on ROSA. It will show the installation of the NetApp Trident CSI driver on a ROSA cluster, the provisioning of an FSx for ONTAP file system, and the deployment of a sample stateful application. It will also show strategies for backing up and restoring your application data. With this integrated solution, you can establish a shared storage framework that effortlessly scales across AZs, simplifying the processes of scaling, protecting, and restoring your data using the Trident CSI driver.
Prerequisites
This diagram shows the ROSA cluster deployed in multiple AZs. ROSA cluster's master nodes, infrastructure nodes are in Red Hat's VPC, while the worker nodes are in a VPC in the customer's account . We'll create an FSx for ONTAP file system within the same VPC and install the Trident driver in the ROSA cluster, allowing all the subnets of this VPC to connect to the file system.
Rosa architecture
Initial Setup
1. Provision FSx for NetApp ONTAP
Create a multi-AZ FSx for NetApp ONTAP in the same VPC as the ROSA cluster. There are several ways to do this. The details of creating FSxN using a CloudFormation Stack are provided
a.Clone the GitHub repository
$ git clone https://github.com/aws-samples/rosa-fsx-netapp-ontap.git
b.Run the CloudFormation Stack
Run the command below by replacing the parameter values with your own values:
$ cd rosa-fsx-netapp-ontap/fsx
$ aws cloudformation create-stack \
  --stack-name ROSA-FSXONTAP \
  --template-body file://./FSxONTAP.yaml \
  --region <region-name> \
  --parameters \
  ParameterKey=Subnet1ID,ParameterValue=[subnet1_ID] \
  ParameterKey=Subnet2ID,ParameterValue=[subnet2_ID] \
  ParameterKey=myVpc,ParameterValue=[VPC_ID] \
ParameterKey=FSxONTAPRouteTable,ParameterValue=[routetable1_ID,routetable2_ID] \
  ParameterKey=FileSystemName,ParameterValue=ROSA-myFSxONTAP \
  ParameterKey=ThroughputCapacity,ParameterValue=1024 \
  ParameterKey=FSxAllowedCIDR,ParameterValue=[your_allowed_CIDR] \
  ParameterKey=FsxAdminPassword,ParameterValue=[Define Admin password] \
  ParameterKey=SvmAdminPassword,ParameterValue=[Define SVM password] \
  --capabilities CAPABILITY_NAMED_IAM
Where :
region-name: same as the region where the ROSA cluster is deployed
subnet1_ID : id of the Preferred subnet for FSxN
subnet2_ID: id of the Standby subnet for FSxN
VPC_ID: id of the VPC where the ROSA cluster is deployed
routetable1_ID, routetable2_ID: ids of the route tables associated with the subnets chosen above
your_allowed_CIDR: allowed CIDR range for the FSx for ONTAP security groups ingress rules to
control access. You can use 0.0.0.0/0 or any appropriate CIDR to allow all
traffic to access the specific ports of FSx for ONTAP.
Define Admin password: A password to login to FSxN
Define SVM password: A password to login to SVM that will be created.
Verify that your file system and storage virtual machine (SVM) has been created using the Amazon FSx console, shown below:
FSxN created
2.Install and configure Trident CSI driver for the ROSA cluster
b.Install Trident
ROSA cluster worker nodes come pre-configured with nfs tools that enable you to use NAS protocols for storage provisioning and access.
If you would like to use iSCSI instead, you need to prepare the worker nodes for iSCSI. Starting from Trident 25.02 release, you can easily prepare the worker nodes of the ROSA cluster(or any OpenShift cluster) to perform iSCSI operations on FSxN storage.
There are 2 easy ways of installing Trident 25.02 (or later) that automates worker node preparation for iSCSI.
1. using the node-prep-flag from the command line using tridentctl tool.
2. Using the Red Hat certified Trident operator from the operator hub and customizing it.
3.Using Helm.
Note Using any of the above methods without enabling the node-prep will allow you to only use NAS protocols for provisioning storage on FSxN.
Method 1: Use tridentctl tool
Use the node-prep flag and install Trident as shown.
Prior to issuing the install command, you should have downloaded installer package. Refer to Download the Trident installer package.
#./tridentctl install trident -n trident --node-prep=iscsi
Method 2: Use the Red Hat Certified Trident Operator and customize
From the OperatorHub, locate the Red Hat certified Trident operator and install it.
Operator in Operator Hub
Install operator 1
Install operator 2
operator installed
Next, create the Trident Orchestrator instance. Use the YAML view to set any custom values or enable iscsi node prep during installation.
orchestrator create
enable NodePrep
orchestrator installed
Trident installed
Installing Trident using any of the above methods will prepare the ROSA cluster worker nodes for iSCSI by starting the iscsid and multipathd services and setting the following in /etc/multipath.conf file
iscsid active
multipathd active
multipath.conf file
c.Verify that all Trident pods are in the running state
Trident pods running
3. Configure the Trident CSI backend to use FSx for ONTAP (ONTAP NAS)
The Trident back-end configuration tells Trident how to communicate with the storage system (in this case, FSx for ONTAP). For creating the backend, we will provide the credentials of the Storage Virtual machine to connect to, along with the Cluster Management and the NFS data interfaces. We will use the ontap-nas driver to provision storage volumes in FSx file system.
a. First, create a secret for the SVM credentials using the following yaml
apiVersion: v1
kind: Secret
metadata:
  namespace: trident
type: Opaque
stringData:
  username: vsadmin
  password: <value provided for Define SVM password as a parameter to the Cloud Formation Stack>
Note You can also retrieve the SVM password created for FSxN from the AWS Secrets Manager as shown below.
AWS secrets Manager
retrieve secret
b.Next, add the secret for the SVM credentials to the ROSA cluster using the following command
$ oc apply -f svm_secret.yaml
You can verify that the secret has been added in the trident namespace using the following command
$ oc get secrets -n trident |grep backend-fsx-ontap-nas-secret
secret applied
c. Next, create the backend object
For this, move into the fsx directory of your cloned Git repository. Open the file backend-ontap-nas.yaml. Replace the following:
managementLIF with the Management DNS name
dataLIF with the NFS DNS name of the Amazon FSx SVM and
svm with the SVM name. Create the backend object using the following command.
$ oc apply -f backend-ontap-nas.yaml
Note You can get the Management DNS name, NFS DNS name and the SVM name from the Amazon FSx Console as shown in the screenshot below
get lifs
d. Now, run the following command to verify that the backend object has been created and Phase is showing Bound and Status is Success
create backend
4. Create Storage Class
Now that the Trident backend is configured, you can create a Kubernetes storage class to use the backend. Storage class is a resource object made available to the cluster. It describes and classifies the type of storage that you can request for an application.
a. Review the file storage-class-csi-nas.yaml in the fsx folder.
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
  backendType: "ontap-nas"
  fsType: "ext4"
allowVolumeExpansion: True
reclaimPolicy: Retain
b. Create Storage Class in ROSA cluster and verify that trident-csi storage class has been created.
create backend
This completes the installation of Trident CSI driver and its connectivity to FSx for ONTAP file system. Now you can deploy a sample Postgresql stateful application on ROSA using file volumes on FSx for ONTAP.
c. Verify that there are no PVCs and PVs created using the trident-csi storage class.
no PVCs using Trident
d. Verify that applications can create PV using Trident CSI.
Create a PVC using the pvc-trident.yaml file provided in the fsx folder.
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 10Gi
  storageClassName: trident-csi
You can issue the following commands to create a pvc and verify that it has been created.
create test PVC using Trident
Note To use iSCSI, you should have enabled iSCSI on the worker nodes as shown previously and you need to create an iSCSI backend and storage class. Here are some sample yaml files.
cat tbc.yaml
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
  username: fsxadmin
  password: <password for the fsxN filesystem>
kind: TridentBackendConfig
metadata:
spec:
  version: 1
  storageDriverName: ontap-san
  managementLIF: <management lif of fsxN filesystem>
  backendName: backend-tbc-ontap-san
  svm: svm_FSxNForROSAiSCSI
  credentials:
cat sc.yaml
kind: StorageClass
metadata:
parameters:
  backendType: "ontap-san"
  media: "ssd"
  provisioningType: "thin"
  snapshots: "true"
allowVolumeExpansion: true
5. Deploy a sample Postgresql stateful application
a. Use helm to install postgresql
$ helm install postgresql bitnami/postgresql -n postgresql --create-namespace
install postgresql
b. Verify that the application pod is running, and a PVC and PV is created for the application.
postgresql pods
postgresql pvc
postgresql pv
c. Deploy a Postgresql client
Use the following command to get the password for the postgresql server that was installed.
$ export POSTGRES_PASSWORD=$(kubectl get secret --namespace postgresql postgresql -o jsonpath="{.data.postgres-password}" | base64 -d)
Use the following command to run a postgresql client and connect to the server using the password
$ kubectl run postgresql-client --rm --tty -i --restart='Never' --namespace postgresql --image docker.io/bitnami/postgresql:16.2.0-debian-11-r1 --env="PGPASSWORD=$POSTGRES_PASSWORD" \
> --command -- psql --host postgresql -U postgres -d postgres -p 5432
postgresql client
d. Create a database and a table. Create a schema for the table and insert 2 rows of data into the table.
postgresql table, schema, rows
postgresql row1
postgresql rows2
