NetApp container solutions
Trident Overview
Contributors banum-netapp kevin-hoke
Trident is an open-source and fully supported storage orchestrator for containers and Kubernetes distributions, including Red Hat OpenShift. Trident works with the entire NetApp storage portfolio, including the NetApp ONTAP and Element storage systems, and it also supports NFS and iSCSI connections. Trident accelerates the DevOps workflow by allowing end users to provision and manage storage from their NetApp storage systems without requiring intervention from a storage administrator.
An administrator can configure a number of storage backends based on project needs and storage system models that enable advanced storage features, including compression, specific disk types, or QoS levels that guarantee a certain level of performance. After they are defined, these backends can be used by developers in their projects to create persistent volume claims (PVCs) and to attach persistent storage to their containers on demand.
Figure showing input/output dialog or representing written content
Trident has a rapid development cycle, and just like Kubernetes, is released four times a year.
A support matrix for what version of Trident has been tested with which Kubernetes distribution can be found in Supported frontends (orchestrators).
Please refer to the Trident product documentation for installation and configuration details.
Download Trident
To install Trident on the deployed user cluster and provision a persistent volume, complete the following steps:
  1. Download the installation archive to the admin workstation and extract the contents. The current version of Trident can be downloaded from the Trident releases page on GitHub.
  2. Extract the Trident install from the downloaded bundle.
    [netapp-user@rhel7 ~]$ tar -xzf trident-installer-22.01.0.tar.gz
    [netapp-user@rhel7 ~]$ cd trident-installer/
    [netapp-user@rhel7 trident-installer]$
Install the Trident Operator with Helm
  1. First set the location of the user cluster's kubeconfig file as an environment variable so that you don't have to reference it, because Trident has no option to pass this file.
    [netapp-user@rhel7 trident-installer]$ export KUBECONFIG=~/ocp-install/auth/kubeconfig
  2. Run the Helm command to install the Trident operator from the tarball in the helm directory while creating the trident namespace in your user cluster.
    [netapp-user@rhel7 trident-installer]$ helm install trident helm/trident-operator-22.01.0.tgz --create-namespace --namespace trident
    LAST DEPLOYED: Fri May  7 12:54:25 2021
    NAMESPACE: trident
    STATUS: deployed
    REVISION: 1
    TEST SUITE: None
    NOTES:
    Thank you for installing trident-operator, which will deploy and manage NetApp's Trident CSI
    storage provisioner for Kubernetes.
    Your release is named 'trident' and is installed into the 'trident' namespace.
    Please note that there must be only one instance of Trident (and trident-operator) in a Kubernetes cluster.
    To configure Trident to manage storage resources, you will need a copy of tridentctl, which is
    available in pre-packaged Trident releases.  You may find all Trident releases and source code
    online at https://github.com/NetApp/trident.
    To learn more about the release, try:
      $ helm status trident
      $ helm get all trident
  3. You can verify that Trident is successfully installed by checking the pods that are running in the namespace or by using the tridentctl binary to check the installed version.
    [netapp-user@rhel7 trident-installer]$ oc get pods -n trident
    NAME                               READY   STATUS    RESTARTS   AGE
    trident-csi-5z45l                  1/2     Running   2          30s
    trident-csi-696b685cf8-htdb2       6/6     Running   0          30s
    trident-csi-b74p2                  2/2     Running   0          30s
    trident-csi-lrw4n                  2/2     Running   0          30s
    trident-operator-7c748d957-gr2gw   1/1     Running   0          36s
    [netapp-user@rhel7 trident-installer]$ ./tridentctl -n trident version
    | SERVER VERSION | CLIENT VERSION |
    | 22.01.0          | 22.01.0          |
Note In some cases, customer environments might require the customization of the Trident deployment. In these cases, it is also possible to manually install the Trident operator and update the included manifests to customize the deployment.
Manually install the Trident Operator
  1. First, set the location of the user cluster's kubeconfig file as an environment variable so that you don't have to reference it, because Trident has no option to pass this file.
  2. The trident-installer directory contains manifests for defining all the required resources. Using the appropriate manifests, create the TridentOrchestrator custom resource definition.
    [netapp-user@rhel7 trident-installer]$ oc create -f deploy/crds/trident.netapp.io_tridentorchestrators_crd_post1.16.yaml
    customresourcedefinition.apiextensions.k8s.io/tridentorchestrators.trident.netapp.io created
  3. If one does not exist, create a Trident namespace in your cluster using the provided manifest.
    [netapp-user@rhel7 trident-installer]$ oc apply -f deploy/namespace.yaml
    namespace/trident created
  4. Create the resources required for the Trident operator deployment, such as a ServiceAccount for the operator, a ClusterRole and ClusterRoleBinding to the ServiceAccount, a dedicated PodSecurityPolicy, or the operator itself.
    [netapp-user@rhel7 trident-installer]$ oc create -f deploy/bundle.yaml
    serviceaccount/trident-operator created
    clusterrole.rbac.authorization.k8s.io/trident-operator created
    clusterrolebinding.rbac.authorization.k8s.io/trident-operator created
    deployment.apps/trident-operator created
    podsecuritypolicy.policy/tridentoperatorpods created
  5. You can check the status of the operator after it's deployed with the following commands:
    [netapp-user@rhel7 trident-installer]$ oc get deployment -n trident
    NAME               READY   UP-TO-DATE   AVAILABLE   AGE
    trident-operator   1/1     1            1           23s
    trident-operator-66f48895cc-lzczk   1/1     Running   0          41s
  6. With the operator deployed, we can now use it to install Trident. This requires creating a TridentOrchestrator.
    [netapp-user@rhel7 trident-installer]$ oc create -f deploy/crds/tridentorchestrator_cr.yaml
    tridentorchestrator.trident.netapp.io/trident created
    [netapp-user@rhel7 trident-installer]$ oc describe torc trident
    Namespace:
    Labels:       <none>
    Annotations:  <none>
    API Version:  trident.netapp.io/v1
    Kind:         TridentOrchestrator
    Metadata:
      Creation Timestamp:  2021-05-07T17:00:28Z
      Generation:          1
      Managed Fields:
        Fields Type:  FieldsV1
        fieldsV1:
          f:spec:
            f:debug:
            f:namespace:
        Manager:      kubectl-create
        Operation:    Update
        Time:         2021-05-07T17:00:28Z
        fieldsV1:
          f:status:
            f:currentInstallationParams:
              f:IPv6:
              f:autosupportHostname:
              f:autosupportimage:
              f:autosupportProxy:
              f:autosupportSerialNumber:
              f:debug:
              f:enableNodePrep:
              f:imagePullSecrets:
              f:imageRegistry:
              f:k8sTimeout:
              f:kubeletDir:
              f:logFormat:
              f:silenceAutosupport:
              f:tridentimage:
            f:message:
            f:namespace:
            f:status:
            f:version:
        Manager:         trident-operator
        Operation:       Update
      Resource Version:  931421
      Self Link:         /apis/trident.netapp.io/v1/tridentorchestrators/trident
      UID:               8a26a7a6-dde8-4d55-9b66-a7126754d81f
    Spec:
      Debug:      true
      Namespace:  trident
    Status:
      Current Installation Params:
        IPv6:                       false
        Autosupport Hostname:
        Autosupport image:          netapp/trident-autosupport:21.01
        Autosupport Proxy:
        Autosupport Serial Number:
        Debug:                      true
        Enable Node Prep:           false
        Image Pull Secrets:
        Image Registry:
        k8sTimeout:           30
        Kubelet Dir:          /var/lib/kubelet
        Log Format:           text
        Silence Autosupport:  false
        Trident image:        netapp/trident:22.01.0
      Message:                Trident installed
      Namespace:              trident
      Status:                 Installed
      Version:                v22.01.0
    Events:
      Type    Reason      Age   From                        Message
      Normal  Installing  80s   trident-operator.netapp.io  Installing Trident
      Normal  Installed   68s   trident-operator.netapp.io  Trident installed
  7. You can verify that Trident is successfully installed by checking the pods that are running in the namespace or by using the tridentctl binary to check the installed version.
    trident-csi-bb64c6cb4-lmd6h         6/6     Running   0          82s
    trident-csi-gn59q                   2/2     Running   0          82s
    trident-csi-m4szj                   2/2     Running   0          82s
    trident-csi-sb9k9                   2/2     Running   0          82s
    trident-operator-66f48895cc-lzczk   1/1     Running   0          2m39s
    | 22.01.0          | 22.01.0          |
Prepare worker nodes for storage
NFS
Most Kubernetes distributions come with the packages and utilities to mount NFS backends installed by default, including Red Hat OpenShift.
However, for NFSv3, there is no mechanism to negotiate concurrency between the client and the server. Hence the maximum number of client-side sunrpc slot table entries must be manually synced with supported value on the server to ensure the best performance for the NFS connection without the server having to decrease the window size of the connection.
For ONTAP, the supported maximum number of sunrpc slot table entries is 128 i.e. ONTAP can serve 128 concurrent NFS requests at a time. However, by default, Red Hat CoreOS/Red Hat Enterprise Linux has maximum of 65,536 sunrpc slot table entries per connection. We need to set this value to 128 and this can be done using Machine Config Operator (MCO) in OpenShift.
To modify the maximum sunrpc slot table entries in OpenShift worker nodes, complete the following steps:
  1. Log into the OCP web console and navigate to Compute > Machine Configs. Click Create Machine Config. Copy and paste the YAML file and click Create.
    apiVersion: machineconfiguration.openshift.io/v1
    kind: MachineConfig
    metadata:
      labels:
        machineconfiguration.openshift.io/role: worker
    spec:
      config:
        ignition:
          version: 3.2.0
        storage:
          files:
            - contents:
                source: data:text/plain;charset=utf-8;base64,b3B0aW9ucyBzdW5ycGMgdGNwX21heF9zbG90X3RhYmxlX2VudHJpZXM9MTI4Cg==
              filesystem: root
              mode: 420
              path: /etc/modprobe.d/sunrpc.conf
  2. After the MCO is created, the configuration needs to be applied on all worker nodes and rebooted one by one. The whole process takes approximately 20 to 30 minutes. Verify whether the machine config is applied by using oc get mcp and make sure that the machine config pool for workers is updated.
    [netapp-user@rhel7 openshift-deploy]$ oc get mcp
    NAME     CONFIG                                    UPDATED   UPDATING   DEGRADED
    master   rendered-master-a520ae930e1d135e0dee7168   True      False      False
    worker   rendered-worker-de321b36eeba62df41feb7bc   True      False      False
iSCSI
To prepare worker nodes to allow for the mapping of block storage volumes through the iSCSI protocol, you must install the necessary packages to support that functionality.
In Red Hat OpenShift, this is handled by applying an MCO (Machine Config Operator) to your cluster after it is deployed.
To configure the worker nodes to run iSCSI services, complete the following steps:
    When not using multipathing:
kind: MachineConfig
metadata:
  labels:
spec:
  config:
    ignition:
      version: 3.2.0
    systemd:
      units:
        - name: iscsid.service
          enabled: true
          state: started
  osImageURL: ""
When using multipathing:
kind: MachineConfig
metadata:
  labels:
spec:
  config:
    ignition:
      version: 3.2.0
    storage:
      files:
      - contents:
          source: data:text/plain;charset=utf-8;base64,ZGVmYXVsdHMgewogICAgICAgIHVzZXJfZnJpZW5kbHlfbmFtZXMgbm8KICAgICAgICBmaW5kX211bHRpcGF0aHMgbm8KfQoKYmxhY2tsaXN0X2V4Y2VwdGlvbnMgewogICAgICAgIHByb3BlcnR5ICIoU0NTSV9JREVOVF98SURfV1dOKSIKfQoKYmxhY2tsaXN0IHsKfQoK
          verification: {}
        filesystem: root
        mode: 400
        path: /etc/multipath.conf
    systemd:
      units:
          enabled: true
          state: started
        - name: multipathd.service
          enabled: true
          state: started
  osImageURL: ""
  1. After the configuration is created, it takes approximately 20 to 30 minutes to apply the configuration to the worker nodes and reload them. Verify whether the machine config is applied by using oc get mcp and make sure that the machine config pool for workers is updated. You can also log into the worker nodes to confirm that the iscsid service is running (and the multipathd service is running if using multipathing).
    [netapp-user@rhel7 openshift-deploy]$ ssh core@10.61.181.22 sudo systemctl status iscsid
    ● iscsid.service - Open-iSCSI
       Loaded: loaded (/usr/lib/systemd/system/iscsid.service; enabled; vendor preset: disabled)
       Active: active (running) since Tue 2021-05-26 13:36:22 UTC; 3 min ago
         Docs: man:iscsid(8)
               man:iscsiadm(8)
     Main PID: 1242 (iscsid)
       Status: "Ready to process requests"
        Tasks: 1
       Memory: 4.9M
          CPU: 9ms
       CGroup: /system.slice/iscsid.service
               └─1242 /usr/sbin/iscsid -f
    [netapp-user@rhel7 openshift-deploy]$ ssh core@10.61.181.22 sudo systemctl status multipathd
     ● multipathd.service - Device-Mapper Multipath Device Controller
       Loaded: loaded (/usr/lib/systemd/system/multipathd.service; enabled; vendor preset: enabled)
      Main PID: 918 (multipathd)
        Status: "up"
        Tasks: 7
        Memory: 13.7M
        CPU: 57ms
        CGroup: /system.slice/multipathd.service
                └─918 /sbin/multipathd -d -s
    Note It is also possible to confirm that the MachineConfig has been successfully applied and services have been started as expected by running the oc debug command with the appropriate flags.
Create storage-system backends
After completing the Trident Operator install, you must configure the backend for the specific NetApp storage platform you are using. Follow the links below in order to continue the setup and configuration of Trident.
