TR-4983: Simplified, Automated Oracle Deployment on NetApp ASA with iSCSI
This solution provides overview and details for automated Oracle deployment and protection in NetApp ASA array as primary database storage with iSCSI protocol and Oracle database configured in standalone ReStart using asm as volume manager.
Purpose
NetApp ASA systems deliver modern solutions to your SAN infrastructure. They simplify at scale and enable you to accelerate your business-critical applications such as databases, make sure that your data is always available (99.9999% uptime), and reduce TCO and carbon footprint. The NetApp ASA systems include A-Series models designed for the most performance-demanding applications and C-Series models optimized for cost-effective, large-capacity deployments. Together, the ASA A-Series and C-Series systems deliver exceptional performance to improve customer experience and reduce time to results, keep business-critical data available, protected, and secure, and provide more effective capacity for any workload, backed by the industry's most effective guarantee.
This documentation demonstrates the simplified deployment of Oracle databases in a SAN environment built with ASA systems using Ansible automation. The Oracle database is deployed in a standalone ReStart configuration with iSCSI protocol for data access and Oracle ASM for database disks management on the ASA storage array. It also provides information on Oracle database backup, restore, and clone using the NetApp SnapCenter UI tool for storage-efficient database operation in NetApp ASA systems.
This solution addresses the following use cases:
Automated Oracle database deployment in NetApp ASA systems as primary database storage
Oracle database backup and restore in NetApp ASA systems using NetApp SnapCenter tool
Oracle database clone for dev/test or other use cases in NetApp ASA systems using NetApp SnapCenter tool
Audience
This solution is intended for the following people:
A DBA who would like to deploy Oracle in NetApp ASA systems.
A database solution architect who would like to test Oracle workloads in NetApp ASA systems.
A storage administrator who would like to deploy and manage an Oracle database on NetApp ASA systems.
An application owner who would like to stand up an Oracle database in NetApp ASA systems.
Solution test and validation environment
The testing and validation of this solution were performed in a lab setting that might not match the final deployment environment. See the section Key factors for deployment consideration for more information.
Architecture
Hardware and software components
Hardware |
NetApp ASA A400 |
Version 9.13.1P1 |
2 NS224 shelves, 48 NVMe AFF drives with total 69.3 TiB capacity |
UCSB-B200-M4 |
Intel® Xeon® CPU E5-2690 v4 @ 2.60GHz |
4-node VMware ESXi cluster |
Software |
RedHat Linux |
RHEL-8.6, 4.18.0-372.9.1.el8.x86_64 kernel |
Deployed RedHat subscription for testing |
Windows Server |
2022 Standard, 10.0.20348 Build 20348 |
Hosting SnapCenter server |
Oracle Grid Infrastructure |
Version 19.18 |
Applied RU patch p34762026_190000_Linux-x86-64.zip |
Oracle Database |
Version 19.18 |
Applied RU patch p34765931_190000_Linux-x86-64.zip |
Oracle OPatch |
Version 12.2.0.1.36 |
Latest patch p6880880_190000_Linux-x86-64.zip |
SnapCenter Server |
Version 4.9P1 |
Workgroup deployment |
VMware vSphere Hypervisor |
version 6.5.0.20000 |
VMware Tools, Version: 11365 - Linux, 12352 - Windows |
Open JDK |
Version java-1.8.0-openjdk.x86_64 |
SnapCenter plugin requirement on DB VMs |
Oracle database configuration in the lab environment
Server |
Database |
DB Storage |
ora_01 |
NTAP1(NTAP1_PDB1,NTAP1_PDB2,NTAP1_PDB3) |
iSCSI luns on ASA A400 |
ora_02 |
NTAP2(NTAP2_PDB1,NTAP2_PDB2,NTAP2_PDB3) |
Oracle database storage layout. In this automated Oracle deployment, we provision four database volumes to host Oracle binary, data, and logs by default. We then create two ASM disk groups from data and logs luns. Within the +DATA asm disk group, we provision two data luns in a volume on each ASA A400 cluster node. Within the +LOGS asm disk group, we create two luns in a log volume on a single ASA A400 node. Multiple luns laid out within an ONTAP volume provides better performance in general.
Multiple DB servers deployment. The automation solution can deploy an Oracle container database to multiple DB servers in a single Ansible playbook run. Regardless of the number of DB servers, the playbook execution remains the same. In the event of multi-DB server deployments, the playbook builds with an algorithm to place database luns on dual controllers of ASA A400 optimally. The binary and logs luns of odd number DB server in server hosts index place on controller 1. The binary and logs luns of even number DB server in the server hosts index place on controller 2. The DB data luns evenly distributed to two controllers. Oracle ASM combines the data luns on two controllers into a single ASM disk group to fully utilize the processing power of both controllers.
iSCSI configuration. The database VMs connect to ASA storage with the iSCSI protocol for storage access. You should configure dual paths on each controller node for redundancy and set up iSCSI multi-path on the DB server for multi-path storage access. Enable jumbo frame on storage network to maximize performance and throughput.
Oracle ASM redundancy level to use for each Oracle ASM disk group that you create. Because the ASA A400 configures storage in RAID DP for data protection at the cluster disk level, you should use
External Redundancy, which means that the option does not allow Oracle ASM to mirror the contents of the disk group. -
Database backup. NetApp provides a SnapCenter software suite for database backup, restore, and cloning with a user-friendly UI interface. NetApp recommends implementing such a management tool to achieve fast (under a minute) SnapShot backup, quick (minutes) database restore, and database clone.
Solution deployment
The following sections provide step-by-step procedures for automated Oracle 19c deployment and protection in NetApp ASA A400 with directly mounted database luns via iSCSI to DB VM in a single node Restart configuration with Oracle ASM as database volume manager.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
It is assumed that the NetApp ASA storage array has been installed and configured. This includes iSCSI broadcast domain, LACP interface groups a0a on both controller nodes, iSCSI VLAN ports (a0a-<iscsi-a-vlan-id>, a0a-<iscsi-b-vlan-id>) on both controller nodes. The following link provides detailed step-by-step instructions if help is needed. Detailed guide - ASA A400
Provision a Linux VM as an Ansible controller node with the latest version of Ansible and Git installed. Refer to the following link for details: Getting Started with NetApp solution automation^ in section -
Setup the Ansible Control Node for CLI deployments on RHEL / CentOSorSetup the Ansible Control Node for CLI deployments on Ubuntu / Debian. -
Clone a copy of the NetApp Oracle deployment automation toolkit for iSCSI.
git clone https://bitbucket.ngage.netapp.com/scm/ns-bb/na_oracle_deploy_iscsi.git -
Provision a Windows server to run the NetApp SnapCenter UI tool with the latest version. Refer to the following link for details: Install the SnapCenter Server
Build two RHEL Oracle DB servers either bare metal or virtualized VM. Create an admin user on DB servers with sudo without password privilege and enable SSH private/public key authentication between Ansible host and Oracle DB server hosts. Stage following Oracle 19c installation files on DB servers /tmp/archive directory.
installer_archives: - "LINUX.X64_193000_grid_home.zip" - "p34762026_190000_Linux-x86-64.zip" - "LINUX.X64_193000_db_home.zip" - "p34765931_190000_Linux-x86-64.zip" - "p6880880_190000_Linux-x86-64.zip"
Ensure that you have allocated at least 50G in Oracle VM root volume to have sufficient space to stage Oracle installation files. -
Watch the following video:
Simplified and automated Oracle deployment on NetApp ASA with iSCSI
Automation parameter files
Details
Ansible playbook executes database installation and configuration tasks with predefined parameters. For this Oracle automation solution, there are three user-defined parameter files that need user input before playbook execution.
hosts - define targets that the automation playbook is running against.
vars/vars.yml - the global variable file that defines variables that apply to all targets.
host_vars/host_name.yml - the local variable file that defines variables that apply only to a local target. In our use case, these are the Oracle DB servers.
In addition to these user-defined variable files, there are several default variable files that contain default parameters that do not require change unless necessary. The following sections show how the user-defined variable files are configured.
Parameter files configuration
Details
Ansible target
hostsfile configuration:# Enter NetApp ASA controller management IP address [ontap] 172.16.9.32 # Enter Oracle servers names to be deployed one by one, follow by each Oracle server public IP address, and ssh private key of admin user for the server. [oracle] ora_01 ansible_host=10.61.180.21 ansible_ssh_private_key_file=ora_01.pem ora_02 ansible_host=10.61.180.23 ansible_ssh_private_key_file=ora_02.pem
Global
vars/vars.ymlfile configuration############################################################################################################# ###### Oracle 19c deployment global user configurable variables ###### ###### Consolidate all variables from ONTAP, linux and oracle ###### ############################################################################################################# ############################################################################################################# ###### ONTAP env specific config variables ###### ############################################################################################################# # Enter the supported ONTAP platform: on-prem, aws-fsx. ontap_platform: on-prem # Enter ONTAP cluster management user credentials username: "xxxxxxxx" password: "xxxxxxxx" ###### on-prem platform specific user defined variables ###### # Enter Oracle SVM iSCSI lif addresses. Each controller configures with dual paths iscsi_a, iscsi_b for redundancy ora_iscsi_lif_mgmt: - {name: '{{ svm_name }}_mgmt', address: 172.21.253.220, netmask: 255.255.255.0, vlan_name: ora_mgmt, vlan_id: 3509} ora_iscsi_lifs_node1: - {name: '{{ svm_name }}_lif_1a', address: 172.21.234.221, netmask: 255.255.255.0, vlan_name: ora_iscsi_a, vlan_id: 3490} - {name: '{{ svm_name }}_lif_1b', address: 172.21.235.221, netmask: 255.255.255.0, vlan_name: ora_iscsi_b, vlan_id: 3491} ora_iscsi_lifs_node2: - {name: '{{ svm_name }}_lif_2a', address: 172.21.234.223, netmask: 255.255.255.0, vlan_name: ora_iscsi_a, vlan_id: 3490} - {name: '{{ svm_name }}_lif_2b', address: 172.21.235.223, netmask: 255.255.255.0, vlan_name: ora_iscsi_b, vlan_id: 3491} ############################################################################################################# ### Linux env specific config variables ### ############################################################################################################# # Enter RHEL subscription to enable repo redhat_sub_username: xxxxxxxx redhat_sub_password: "xxxxxxxx" ############################################################################################################# ### Oracle DB env specific config variables ### ############################################################################################################# # Enter Database domain name db_domain: solutions.netapp.com # Enter initial password for all required Oracle passwords. Change them after installation. initial_pwd_all: xxxxxxxx
Local DB server
host_vars/host_name.ymlconfiguration# User configurable Oracle host specific parameters # Enter container database SID. By default, a container DB is created with 3 PDBs within the CDB oracle_sid: NTAP1 # Enter database shared memory size or SGA. CDB is created with SGA at 75% of memory_limit, MB. The grand total of SGA should not exceed 75% available RAM on node. memory_limit: 8192
Playbook execution
Details
There are a total of six playbooks in the automation toolkit. Each performs different task blocks and serves different purposes.
0-all_playbook.yml - execute playbooks from 1-4 in one playbook run. 1-ansible_requirements.yml - set up Ansible controller with required libs and collections. 2-linux_config.yml - execute Linux kernel configuration on Oracle DB servers. 3-ontap_config.yml - configure ONTAP svm/volumes/luns for Oracle database and grant DB server access to luns. 4-oracle_config.yml - install and configure Oracle on DB servers for grid infrastructure and create a container database. 5-destroy.yml - optional to undo the environment to dismantle all.
There are three options to run the playbooks with the following commands.
Execute all deployment playbooks in one combined run.
ansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -
Execute playbooks one at a time with the number sequence from 1-4.
ansible-playbook -i hosts 1-ansible_requirements.yml -u admin -e @vars/vars.ymlansible-playbook -i hosts 2-linux_config.yml -u admin -e @vars/vars.ymlansible-playbook -i hosts 3-ontap_config.yml -u admin -e @vars/vars.ymlansible-playbook -i hosts 4-oracle_config.yml -u admin -e @vars/vars.yml -
Execute 0-all_playbook.yml with a tag.
ansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -t ansible_requirementsansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -t linux_configansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -t ontap_configansible-playbook -i hosts 0-all_playbook.yml -u admin -e @vars/vars.yml -t oracle_config -
Undo the environment
ansible-playbook -i hosts 5-destroy.yml -u admin -e @vars/vars.yml
Post execution validation
Details
After the playbook run, login to the Oracle DB server as oracle user to validate that Oracle grid infrastructure and database are created successfully. Following is an example of Oracle database validation on host ora_01.
Validate the grid infrastructure and resources created.
[oracle@ora_01 ~]$ df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 40K 7.7G 1% /dev tmpfs 7.8G 1.1G 6.7G 15% /dev/shm tmpfs 7.8G 312M 7.5G 4% /run tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup /dev/mapper/rhel-root 44G 38G 6.8G 85% / /dev/sda1 1014M 258M 757M 26% /boot tmpfs 1.6G 12K 1.6G 1% /run/user/42 tmpfs 1.6G 4.0K 1.6G 1% /run/user/1000 /dev/mapper/ora_01_biny_01p1 40G 21G 20G 52% /u01 [oracle@ora_01 ~]$ asm [oracle@ora_01 ~]$ crsctl stat res -t -------------------------------------------------------------------------------- Name Target State Server State details -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE ora_01 STABLE ora.LISTENER.lsnr ONLINE INTERMEDIATE ora_01 Not All Endpoints Re gistered,STABLE ora.LOGS.dg ONLINE ONLINE ora_01 STABLE ora.asm ONLINE ONLINE ora_01 Started,STABLE ora.ons OFFLINE OFFLINE ora_01 STABLE -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.cssd 1 ONLINE ONLINE ora_01 STABLE ora.diskmon 1 OFFLINE OFFLINE STABLE ora.driver.afd 1 ONLINE ONLINE ora_01 STABLE ora.evmd 1 ONLINE ONLINE ora_01 STABLE ora.ntap1.db 1 ONLINE ONLINE ora_01 Open,HOME=/u01/app/o racle/product/19.0.0 /NTAP1,STABLE -------------------------------------------------------------------------------- [oracle@ora_01 ~]$Ignore the Not All Endpoints Registeredin State details. This results from a conflict of manual and dynamic database registration with the listener and can be safely ignored. -
Validate ASM filter driver is working as expected.
[oracle@ora_01 ~]$ asmcmd ASMCMD> lsdg State Type Rebal Sector Logical_Sector Block AU Total_MB Free_MB Req_mir_free_MB Usable_file_MB Offline_disks Voting_files Name MOUNTED EXTERN N 512 512 4096 4194304 327680 318644 0 318644 0 N DATA/ MOUNTED EXTERN N 512 512 4096 4194304 81920 78880 0 78880 0 N LOGS/ ASMCMD> lsdsk Path AFD:ORA_01_DAT1_01 AFD:ORA_01_DAT1_03 AFD:ORA_01_DAT1_05 AFD:ORA_01_DAT1_07 AFD:ORA_01_DAT2_02 AFD:ORA_01_DAT2_04 AFD:ORA_01_DAT2_06 AFD:ORA_01_DAT2_08 AFD:ORA_01_LOGS_01 AFD:ORA_01_LOGS_02 ASMCMD> afd_state ASMCMD-9526: The AFD state is 'LOADED' and filtering is 'ENABLED' on host 'ora_01' ASMCMD>
Login to Oracle Enterprise Manager Express to validate database.
Enable additional port from sqlplus for login to individual container database or PDBs. SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP1_PDB1 READ WRITE NO 4 NTAP1_PDB2 READ WRITE NO 5 NTAP1_PDB3 READ WRITE NO SQL> alter session set container=NTAP1_PDB1; Session altered. SQL> select dbms_xdb_config.gethttpsport() from dual; DBMS_XDB_CONFIG.GETHTTPSPORT() ------------------------------ 0 SQL> exec DBMS_XDB_CONFIG.SETHTTPSPORT(5501); PL/SQL procedure successfully completed. SQL> select dbms_xdb_config.gethttpsport() from dual; DBMS_XDB_CONFIG.GETHTTPSPORT() ------------------------------ 5501 login to NTAP1_PDB1 from port 5501.
Oracle backup, restore, and clone with SnapCenter
Details
Refer to TR-4979 Simplified, self-managed Oracle in VMware Cloud on AWS with guest-mounted FSx ONTAP section Oracle backup, restore, and clone with SnapCenter for details on setting up SnapCenter and executing the database backup, restore, and clone workflows.
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
NETAPP ASA: ALL-FLASH SAN ARRAY
Installing Oracle Grid Infrastructure for a Standalone Server with a New Database Installation
Installing and Configuring Oracle Database Using Response Files
Use Red Hat Enterprise Linux 8.2 with ONTAP
