TR-4979: Simplified, Self-managed Oracle in VMware Cloud on AWS with guest-mounted FSx ONTAP
This solution provides overview and details for Oracle deployment and protection in VMware Cloud in AWS with FSx ONTAP as primary database storage and Oracle database configured in standalone ReStart using asm as volume manager.
Purpose
Enterprises have been running Oracle on VMware in private data centers for decades. VMware Cloud (VMC) on AWS provides a push-button solution to bring VMware's enterprise-class Software-Defined Data Center (SDDC) software to the AWS Cloud's dedicated, elastic, bare-metal infrastructure. AWS FSx ONTAP offers premium storage to VMC SDDC and a data fabric that enables customers to run business-critical applications such as Oracle across vSphere-based private, public, and hybrid cloud environments, with optimized access to AWS services. Whether it is an existing or new Oracle workload, VMC on AWS provides a familiar, simplified, and self-managed Oracle environment on VMware with all the benefits of AWS cloud while deferring all platform management and optimization to VMware.
This documentation demonstrates the deployment and protection of an Oracle database in a VMC environment with Amazon FSx ONTAP as primary database storage. Oracle database can be deployed to VMC on FSx storage as direct VM guest-mounted LUNs or NFS-mounted VMware VMDK datastore disks. This technical report focuses on Oracle database deployment as direct guest-mounted FSx storage to VMs in the VMC cluster with the iSCSI protocol and Oracle ASM. We also demonstrate how to use the NetApp SnapCenter UI tool to backup, restore, and clone an Oracle database for dev/test or other use cases for storage-efficient database operation in the VMC on AWS.
This solution addresses the following use cases:
Oracle database deployment in VMC on AWS with Amazon FSx ONTAP as primary database storage
Oracle database backup and restore in VMC on AWS using NetApp SnapCenter tool
Oracle database clone for dev/test or other use cases in VMC on AWS using NetApp SnapCenter tool
Audience
This solution is intended for the following people:
A DBA who would like to deploy Oracle in VMC on AWS with Amazon FSx ONTAP
A database solution architect who would like to test Oracle workloads in VMC on the AWS cloud
A storage administrator who would like to deploy and manage an Oracle database deployed to VMC on AWS with Amazon FSx ONTAP
An application owner who would like to stand up an Oracle database in VMC on the AWS cloud
Solution test and validation environment
The testing and validation of this solution was performed in a lab environment with VMC on AWS that might not match the final deployment environment. For more information, see the section Key factors for deployment consideration.
Architecture
Hardware and software components
Hardware |
FSx ONTAP storage |
Current version offered by AWS |
One FSx ONTAP HA cluster in the same VPC and availability zone as VMC |
VMC SDDC cluster |
Amazon EC2 i3.metal single node/Intel Xeon E5-2686 CPU,36 cores/512G RAM |
10.37 TB vSAN storage |
Software |
RedHat Linux |
RHEL-8.6, 4.18.0-372.9.1.el8.x86_64 kernel |
Deployed RedHat subscription for testing |
Windows Server |
2022 Standard, 10.0.20348 Build 20348 |
Hosting SnapCenter server |
Oracle Grid Infrastructure |
Version 19.18 |
Applied RU patch p34762026_190000_Linux-x86-64.zip |
Oracle Database |
Version 19.18 |
Applied RU patch p34765931_190000_Linux-x86-64.zip |
Oracle OPatch |
Version 12.2.0.1.36 |
Latest patch p6880880_190000_Linux-x86-64.zip |
SnapCenter Server |
Version 4.9P1 |
Workgroup deployment |
BlueXP backup and recovery for VMs |
Release 1.0 |
Deployed as an ova vSphere plugin VM |
VMware vSphere |
Version 8.0.1.00300 |
VMware Tools, Version: 11365 - Linux, 12352 - Windows |
Open JDK |
Version java-1.8.0-openjdk.x86_64 |
SnapCenter plugin requirement on DB VMs |
Oracle database configuration in VMC on AWS
Server |
Database |
DB Storage |
ora_01 |
cdb1(cdb1_pdb1,cdb1_pdb2,cdb1_pdb3) |
VMDK datastore on FSx ONTAP |
ora_01 |
cdb2(cdb2_pdb) |
ora_02 |
cdb3(cdb3_pdb1,cdb3_pdb2,cdb3_pdb3) |
Direct guest mounted FSx ONTAP |
ora_02 |
cdb4(cdb4_pdb) |
FSx to VMC connectivity. When you deploy your SDDC on VMware Cloud on AWS, it is created within an AWS account and a VPC dedicated to your organization and managed by VMware. You must also connect the SDDC to an AWS account belonging to you, called the customer AWS account. This connection allows your SDDC to access AWS services belonging to your customer account. FSx ONTAP is an AWS service deployed in your customer account. Once the VMC SDDC is connected to your customer account, FSx storage is available to VMs in VMC SDDC for direct guest mount.
FSx storage HA clusters single- or multi-zone deployment. In these tests and validations, we deployed an FSx HA cluster in a single AWS availability zone. NetApp also recommends deploying FSx ONTAP and VMware Cloud on AWS in the same availability zone to achieve better performance and avoid data transfer charges between availability zones.
FSx storage cluster sizing. An Amazon FSx ONTAP storage file system provides up to 160,000 raw SSD IOPS, up to 4GBps throughput, and a maximum of 192TiB capacity. However, you can size the cluster in terms of provisioned IOPS, throughput, and storage limit (minimum 1,024 GiB) based on your actual requirements at the time of deployment. The capacity can be adjusted dynamically on the fly without affecting application availability.
Oracle data and logs layout. In our tests and validations, we deployed two ASM disk groups for data and logs respectively. Within the +DATA asm disk group, we provisioned four LUNs in a data volume. Within the +LOGS asm disk group, we provisioned two LUNs in a log volume. In general, multiple LUNs laid out within an Amazon FSx ONTAP volume provide better performance.
iSCSI configuration. The database VMs in VMC SDDC connect to FSx storage with the iSCSI protocol. It is important to gauge the Oracle database peak I/O throughput requirement by carefully analyzing the Oracle AWR report to determine the application and iSCSI traffic-throughput requirements. NetApp also recommends allocating four iSCSI connections to both FSx iSCSI endpoints with multipath properly configured.
Oracle ASM redundancy level to use for each Oracle ASM disk group that you create. Because FSx ONTAP already mirrors the storage on the FSx cluster level, you should use External Redundancy, which means that the option does not allow Oracle ASM to mirror the contents of the disk group.
Database backup. NetApp provides a SnapCenter software suite for database backup, restore, and cloning with a user-friendly UI interface. NetApp recommends implementing such a management tool to achieve fast (under a minute) SnapShot backup, quick (minutes) database restore, and database clone.
Solution deployment
The following sections provide step-by-step procedures for Oracle 19c deployment in VMC on AWS with directly mounted FSx ONTAP storage to DB VM in a single node Restart configuration with Oracle ASM as database volume manager.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
A software-defined data center (SDDC) using VMware Cloud on AWS has been created. For detailed instruction on how to create an SDDC in VMC, please refer to VMware documentation Getting Started With VMware Cloud on AWS
An AWS account has been set up, and the necessary VPC and network segments have been created within your AWS account. The AWS account is linked to your VMC SDDC.
From the AWS EC2 console, deploying an Amazon FSx ONTAP storage HA clusters to host the Oracle database volumes. If you are not familiar with the deployment of FSx storage, see the documentation Creating FSx ONTAP file systems for step-by-step instructions.
The above step can be performed using the following Terraform automation toolkit, which creates an EC2 instance as a jump host for SDDC in VMC access via SSH and an FSx file system. Review instructions carefully and change the variables to suit your environment before execution.
git clone https://github.com/NetApp-Automation/na_aws_fsx_ec2_deploy.git
Build VMs in VMware SDDC on AWS for hosting your Oracle environment to be deployed in VMC. In our demonstration, we have built two Linux VMs as Oracle DB servers, one Windows server for the SnapCenter server, and one optional Linux server as an Ansible controller for automated Oracle installation or configuration if desired. Following is a snapshot of the lab environment for the solution validation.
Optionally, NetApp also provides several automation toolkits to run Oracle deployment and configuration when applicable.
Ensure that you have allocated at least 50G in Oracle VM root volume in order to have sufficient space to stage Oracle installation files. |
DB VM kernel configuration
Details
With the prerequisites provisioned, login to the Oracle VM as an admin user via SSH and sudo to the root user to configure the Linux kernel for Oracle installation. Oracle install files can be staged in an AWS S3 bucket and transferred into the VM.
Create a staging directory
/tmp/archivefolder and set the777permission.mkdir /tmp/archivechmod 777 /tmp/archive -
Download and stage the Oracle binary installation files and other required rpm files to the
/tmp/archivedirectory.See the following list of installation files to be stated in
/tmp/archiveon the DB VM.[admin@ora_02 ~]$ ls -l /tmp/archive/ total 10539364 -rw-rw-r--. 1 admin admin 19112 Oct 4 17:04 compat-libcap1-1.10-7.el7.x86_64.rpm -rw-rw-r--. 1 admin admin 3059705302 Oct 4 17:10 LINUX.X64_193000_db_home.zip -rw-rw-r--. 1 admin admin 2889184573 Oct 4 17:11 LINUX.X64_193000_grid_home.zip -rw-rw-r--. 1 admin admin 589145 Oct 4 17:04 netapp_linux_unified_host_utilities-7-1.x86_64.rpm -rw-rw-r--. 1 admin admin 31828 Oct 4 17:04 oracle-database-preinstall-19c-1.0-2.el8.x86_64.rpm -rw-rw-r--. 1 admin admin 2872741741 Oct 4 17:12 p34762026_190000_Linux-x86-64.zip -rw-rw-r--. 1 admin admin 1843577895 Oct 4 17:13 p34765931_190000_Linux-x86-64.zip -rw-rw-r--. 1 admin admin 124347218 Oct 4 17:13 p6880880_190000_Linux-x86-64.zip -rw-rw-r--. 1 admin admin 257136 Oct 4 17:04 policycoreutils-python-utils-2.9-9.el8.noarch.rpm [admin@ora_02 ~]$
Install Oracle 19c preinstall RPM, which satisfies most kernel configuration requirements.
yum install /tmp/archive/oracle-database-preinstall-19c-1.0-2.el8.x86_64.rpm -
Download and install the missing
compat-libcap1in Linux 8.yum install /tmp/archive/compat-libcap1-1.10-7.el7.x86_64.rpm -
From NetApp, download and install NetApp host utilities.
yum install /tmp/archive/netapp_linux_unified_host_utilities-7-1.x86_64.rpm -
Install
policycoreutils-python-utils.yum install /tmp/archive/policycoreutils-python-utils-2.9-9.el8.noarch.rpm -
Install open JDK version 1.8.
yum install java-1.8.0-openjdk.x86_64 -
Install iSCSI initiator utils.
yum install iscsi-initiator-utils -
Install sg3_utils.
yum install sg3_utils -
Install device-mapper-multipath.
yum install device-mapper-multipath -
Disable transparent hugepages in the current system.
echo never > /sys/kernel/mm/transparent_hugepage/enabledecho never > /sys/kernel/mm/transparent_hugepage/defrag -
Add the following lines in
/etc/rc.localto disabletransparent_hugepageafter reboot.vi /etc/rc.local# Disable transparent hugepages if test -f /sys/kernel/mm/transparent_hugepage/enabled; then echo never > /sys/kernel/mm/transparent_hugepage/enabled fi if test -f /sys/kernel/mm/transparent_hugepage/defrag; then echo never > /sys/kernel/mm/transparent_hugepage/defrag fi -
Disable selinux by changing
SELINUX=enforcingtoSELINUX=disabled. You must reboot the host to make the change effective.vi /etc/sysconfig/selinux -
Add the following lines to
limit.confto set the file descriptor limit and stack size.vi /etc/security/limits.conf* hard nofile 65536 * soft stack 10240
Add swap space to DB VM if there is no swap space configured with this instruction: How do I allocate memory to work as swap space in an Amazon EC2 instance by using a swap file? The exact amount of space to add depends on the size of RAM up to 16G.
Change
node.session.timeo.replacement_timeoutin theiscsi.confconfiguration file from 120 to 5 seconds.vi /etc/iscsi/iscsid.conf -
Enable and start the iSCSI service on the EC2 instance.
systemctl enable iscsidsystemctl start iscsid -
Retrieve the iSCSI initiator address to be used for database LUN mapping.
cat /etc/iscsi/initiatorname.iscsi -
Add the asm groups for asm management user (oracle).
groupadd asmadmingroupadd asmdbagroupadd asmoper -
Modify the oracle user to add asm groups as secondary groups (the oracle user should have been created after Oracle preinstall RPM installation).
usermod -a -G asmadmin oracleusermod -a -G asmdba oracleusermod -a -G asmoper oracle -
Stop and disable the Linux firewall if it is active.
systemctl stop firewalldsystemctl disable firewalld -
Enable password-less sudo for admin user by uncommenting
# %wheel ALL=(ALL) NOPASSWD: ALLline in /etc/sudoers file. Change the file permission to make the edit.chmod 640 /etc/sudoersvi /etc/sudoerschmod 440 /etc/sudoers -
Reboot the EC2 instance.
Provision and map FSx ONTAP LUNs to the DB VM
Details
Provision three volumes from the command line by login to FSx cluster as fsxadmin user via ssh and FSx cluster management IP. Create LUNs within the volumes to host the Oracle database binary, data, and logs files.
Log into the FSx cluster through SSH as the fsxadmin user.
ssh fsxadmin@10.49.0.74 -
Execute the following command to create a volume for the Oracle binary.
vol create -volume ora_02_biny -aggregate aggr1 -size 50G -state online -type RW -snapshot-policy none -tiering-policy snapshot-only -
Execute the following command to create a volume for Oracle data.
vol create -volume ora_02_data -aggregate aggr1 -size 100G -state online -type RW -snapshot-policy none -tiering-policy snapshot-only -
Execute the following command to create a volume for Oracle logs.
vol create -volume ora_02_logs -aggregate aggr1 -size 100G -state online -type RW -snapshot-policy none -tiering-policy snapshot-only -
Validate the volumes created.
vol show ora*Output from the command:
FsxId0c00cec8dad373fd1::> vol show ora* Vserver Volume Aggregate State Type Size Available Used% --------- ------------ ------------ ---------- ---- ---------- ---------- ----- nim ora_02_biny aggr1 online RW 50GB 22.98GB 51% nim ora_02_data aggr1 online RW 100GB 18.53GB 80% nim ora_02_logs aggr1 online RW 50GB 7.98GB 83%
Create a binary LUN within the database binary volume.
lun create -path /vol/ora_02_biny/ora_02_biny_01 -size 40G -ostype linux -
Create data LUNs within the database data volume.
lun create -path /vol/ora_02_data/ora_02_data_01 -size 20G -ostype linuxlun create -path /vol/ora_02_data/ora_02_data_02 -size 20G -ostype linuxlun create -path /vol/ora_02_data/ora_02_data_03 -size 20G -ostype linuxlun create -path /vol/ora_02_data/ora_02_data_04 -size 20G -ostype linux -
Create log LUNs within the database logs volume.
lun create -path /vol/ora_02_logs/ora_02_logs_01 -size 40G -ostype linuxlun create -path /vol/ora_02_logs/ora_02_logs_02 -size 40G -ostype linux -
Create an igroup for the EC2 instance with the initiator retrieved from step 14 of the EC2 kernel configuration above.
igroup create -igroup ora_02 -protocol iscsi -ostype linux -initiator iqn.1994-05.com.redhat:f65fed7641c2 -
Map the LUNs to the igroup created above. Increment the LUN ID sequentially for each additional LUN.
lun map -path /vol/ora_02_biny/ora_02_biny_01 -igroup ora_02 -vserver svm_ora -lun-id 0 lun map -path /vol/ora_02_data/ora_02_data_01 -igroup ora_02 -vserver svm_ora -lun-id 1 lun map -path /vol/ora_02_data/ora_02_data_02 -igroup ora_02 -vserver svm_ora -lun-id 2 lun map -path /vol/ora_02_data/ora_02_data_03 -igroup ora_02 -vserver svm_ora -lun-id 3 lun map -path /vol/ora_02_data/ora_02_data_04 -igroup ora_02 -vserver svm_ora -lun-id 4 lun map -path /vol/ora_02_logs/ora_02_logs_01 -igroup ora_02 -vserver svm_ora -lun-id 5 lun map -path /vol/ora_02_logs/ora_02_logs_02 -igroup ora_02 -vserver svm_ora -lun-id 6 -
Validate the LUN mapping.
mapping showThis is expected to return:
FsxId0c00cec8dad373fd1::> mapping show (lun mapping show) Vserver Path Igroup LUN ID Protocol ---------- ---------------------------------------- ------- ------ -------- nim /vol/ora_02_biny/ora_02_u01_01 ora_02 0 iscsi nim /vol/ora_02_data/ora_02_u02_01 ora_02 1 iscsi nim /vol/ora_02_data/ora_02_u02_02 ora_02 2 iscsi nim /vol/ora_02_data/ora_02_u02_03 ora_02 3 iscsi nim /vol/ora_02_data/ora_02_u02_04 ora_02 4 iscsi nim /vol/ora_02_logs/ora_02_u03_01 ora_02 5 iscsi nim /vol/ora_02_logs/ora_02_u03_02 ora_02 6 iscsi
DB VM storage configuration
Details
Now, import and set up the FSx ONTAP storage for the Oracle grid infrastructure and database installation on the VMC database VM.
Login to the DB VM via SSH as the admin user using Putty from Windows jump server.
Discover the FSx iSCSI endpoints using either SVM iSCSI IP address. Change to your environment-specific portal address.
sudo iscsiadm iscsiadm --mode discovery --op update --type sendtargets --portal 10.49.0.12 -
Establish iSCSI sessions by logging into each target.
sudo iscsiadm --mode node -l allThe expected output from the command is:
[ec2-user@ip-172-30-15-58 ~]$ sudo iscsiadm --mode node -l all Logging in to [iface: default, target: iqn.1992-08.com.netapp:sn.1f795e65c74911edb785affbf0a2b26e:vs.3, portal: 10.49.0.12,3260] Logging in to [iface: default, target: iqn.1992-08.com.netapp:sn.1f795e65c74911edb785affbf0a2b26e:vs.3, portal: 10.49.0.186,3260] Login to [iface: default, target: iqn.1992-08.com.netapp:sn.1f795e65c74911edb785affbf0a2b26e:vs.3, portal: 10.49.0.12,3260] successful. Login to [iface: default, target: iqn.1992-08.com.netapp:sn.1f795e65c74911edb785affbf0a2b26e:vs.3, portal: 10.49.0.186,3260] successful.
View and validate a list of active iSCSI sessions.
sudo iscsiadm --mode sessionReturn the iSCSI sessions.
[ec2-user@ip-172-30-15-58 ~]$ sudo iscsiadm --mode session tcp: [1] 10.49.0.186:3260,1028 iqn.1992-08.com.netapp:sn.545a38bf06ac11ee8503e395ab90d704:vs.3 (non-flash) tcp: [2] 10.49.0.12:3260,1029 iqn.1992-08.com.netapp:sn.545a38bf06ac11ee8503e395ab90d704:vs.3 (non-flash)
Verify that the LUNs were imported into the host.
sudo sanlun lun showThis will return a list of Oracle LUNs from FSx.
[admin@ora_02 ~]$ sudo sanlun lun show controller(7mode/E-Series)/ device host lun vserver(cDOT/FlashRay) lun-pathname filename adapter protocol size product ------------------------------------------------------------------------------------------------------------------------------- nim /vol/ora_02_logs/ora_02_u03_02 /dev/sdo host34 iSCSI 20g cDOT nim /vol/ora_02_logs/ora_02_u03_01 /dev/sdn host34 iSCSI 20g cDOT nim /vol/ora_02_data/ora_02_u02_04 /dev/sdm host34 iSCSI 20g cDOT nim /vol/ora_02_data/ora_02_u02_03 /dev/sdl host34 iSCSI 20g cDOT nim /vol/ora_02_data/ora_02_u02_02 /dev/sdk host34 iSCSI 20g cDOT nim /vol/ora_02_data/ora_02_u02_01 /dev/sdj host34 iSCSI 20g cDOT nim /vol/ora_02_biny/ora_02_u01_01 /dev/sdi host34 iSCSI 40g cDOT nim /vol/ora_02_logs/ora_02_u03_02 /dev/sdh host33 iSCSI 20g cDOT nim /vol/ora_02_logs/ora_02_u03_01 /dev/sdg host33 iSCSI 20g cDOT nim /vol/ora_02_data/ora_02_u02_04 /dev/sdf host33 iSCSI 20g cDOT nim /vol/ora_02_data/ora_02_u02_03 /dev/sde host33 iSCSI 20g cDOT nim /vol/ora_02_data/ora_02_u02_02 /dev/sdd host33 iSCSI 20g cDOT nim /vol/ora_02_data/ora_02_u02_01 /dev/sdc host33 iSCSI 20g cDOT nim /vol/ora_02_biny/ora_02_u01_01 /dev/sdb host33 iSCSI 40g cDOT
Configure the
multipath.conffile with following default and blacklist entries.sudo vi /etc/multipath.confAdd following entries:
defaults { find_multipaths yes user_friendly_names yes } blacklist { devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*" devnode "^hd[a-z]" devnode "^cciss.*" } -
Start the multipath service.
sudo systemctl start multipathdNow multipath devices appear in the
/dev/mapperdirectory.[ec2-user@ip-172-30-15-58 ~]$ ls -l /dev/mapper total 0 lrwxrwxrwx 1 root root 7 Mar 21 20:13 3600a09806c574235472455534e68512d -> ../dm-0 lrwxrwxrwx 1 root root 7 Mar 21 20:13 3600a09806c574235472455534e685141 -> ../dm-1 lrwxrwxrwx 1 root root 7 Mar 21 20:13 3600a09806c574235472455534e685142 -> ../dm-2 lrwxrwxrwx 1 root root 7 Mar 21 20:13 3600a09806c574235472455534e685143 -> ../dm-3 lrwxrwxrwx 1 root root 7 Mar 21 20:13 3600a09806c574235472455534e685144 -> ../dm-4 lrwxrwxrwx 1 root root 7 Mar 21 20:13 3600a09806c574235472455534e685145 -> ../dm-5 lrwxrwxrwx 1 root root 7 Mar 21 20:13 3600a09806c574235472455534e685146 -> ../dm-6 crw------- 1 root root 10, 236 Mar 21 18:19 control
Log into the FSx ONTAP cluster as the fsxadmin user via SSH to retrieve the serial-hex number for each LUN starting with 6c574xxx…, the HEX number starts with 3600a0980, which is the AWS vendor ID.
lun show -fields serial-hexand return as follow:
FsxId02ad7bf3476b741df::> lun show -fields serial-hex vserver path serial-hex ------- ------------------------------- ------------------------ svm_ora /vol/ora_02_biny/ora_02_biny_01 6c574235472455534e68512d svm_ora /vol/ora_02_data/ora_02_data_01 6c574235472455534e685141 svm_ora /vol/ora_02_data/ora_02_data_02 6c574235472455534e685142 svm_ora /vol/ora_02_data/ora_02_data_03 6c574235472455534e685143 svm_ora /vol/ora_02_data/ora_02_data_04 6c574235472455534e685144 svm_ora /vol/ora_02_logs/ora_02_logs_01 6c574235472455534e685145 svm_ora /vol/ora_02_logs/ora_02_logs_02 6c574235472455534e685146 7 entries were displayed.
Update the
/dev/multipath.conffile to add a user-friendly name for the multipath device.sudo vi /etc/multipath.confwith following entries:
multipaths { multipath { wwid 3600a09806c574235472455534e68512d alias ora_02_biny_01 } multipath { wwid 3600a09806c574235472455534e685141 alias ora_02_data_01 } multipath { wwid 3600a09806c574235472455534e685142 alias ora_02_data_02 } multipath { wwid 3600a09806c574235472455534e685143 alias ora_02_data_03 } multipath { wwid 3600a09806c574235472455534e685144 alias ora_02_data_04 } multipath { wwid 3600a09806c574235472455534e685145 alias ora_02_logs_01 } multipath { wwid 3600a09806c574235472455534e685146 alias ora_02_logs_02 } } -
Reboot the multipath service to verify that the devices under
/dev/mapperhave changed to LUN names versus serial-hex IDs.sudo systemctl restart multipathdCheck
/dev/mapperto return as following:[ec2-user@ip-172-30-15-58 ~]$ ls -l /dev/mapper total 0 crw------- 1 root root 10, 236 Mar 21 18:19 control lrwxrwxrwx 1 root root 7 Mar 21 20:41 ora_02_biny_01 -> ../dm-0 lrwxrwxrwx 1 root root 7 Mar 21 20:41 ora_02_data_01 -> ../dm-1 lrwxrwxrwx 1 root root 7 Mar 21 20:41 ora_02_data_02 -> ../dm-2 lrwxrwxrwx 1 root root 7 Mar 21 20:41 ora_02_data_03 -> ../dm-3 lrwxrwxrwx 1 root root 7 Mar 21 20:41 ora_02_data_04 -> ../dm-4 lrwxrwxrwx 1 root root 7 Mar 21 20:41 ora_02_logs_01 -> ../dm-5 lrwxrwxrwx 1 root root 7 Mar 21 20:41 ora_02_logs_02 -> ../dm-6
Partition the binary LUN with a single primary partition.
sudo fdisk /dev/mapper/ora_02_biny_01 -
Format the partitioned binary LUN with an XFS file system.
sudo mkfs.xfs /dev/mapper/ora_02_biny_01p1 -
Mount the binary LUN to
/u01.sudo mkdir /u01sudo mount -t xfs /dev/mapper/ora_02_biny_01p1 /u01 -
Change
/u01mount point ownership to the oracle user and it's associated primary group.sudo chown oracle:oinstall /u01 -
Find the UUI of the binary LUN.
sudo blkid /dev/mapper/ora_02_biny_01p1 -
Add a mount point to
/etc/fstab.sudo vi /etc/fstabAdd the following line.
UUID=d89fb1c9-4f89-4de4-b4d9-17754036d11d /u01 xfs defaults,nofail 0 2
As the root user, add the udev rule for Oracle devices.
vi /etc/udev/rules.d/99-oracle-asmdevices.rulesInclude following entries:
ENV{DM_NAME}=="ora*", GROUP:="oinstall", OWNER:="oracle", MODE:="660" -
As the root user, reload the udev rules.
udevadm control --reload-rules -
As the root user, trigger the udev rules.
udevadm trigger -
As the root user, reload multipathd.
systemctl restart multipathd -
Reboot the EC2 instance host.
Oracle grid infrastructure installation
Details
Log into the DB VM as the admin user via SSH and enable password authentication by uncommenting
PasswordAuthentication yesand then commenting outPasswordAuthentication no.sudo vi /etc/ssh/sshd_config -
Restart the sshd service.
sudo systemctl restart sshd -
Reset the Oracle user password.
sudo passwd oracle -
Log in as the Oracle Restart software owner user (oracle). Create an Oracle directory as follows:
mkdir -p /u01/app/oraclemkdir -p /u01/app/oraInventory -
Change the directory permission setting.
chmod -R 775 /u01/app -
Create a grid home directory and change to it.
mkdir -p /u01/app/oracle/product/19.0.0/gridcd /u01/app/oracle/product/19.0.0/grid -
Unzip the grid installation files.
unzip -q /tmp/archive/LINUX.X64_193000_grid_home.zip -
From grid home, delete the
OPatchdirectory.rm -rf OPatch -
From grid home, unzip
p6880880_190000_Linux-x86-64.zip.unzip -q /tmp/archive/p6880880_190000_Linux-x86-64.zip -
From grid home, revise
cv/admin/cvu_config, uncomment and replaceCV_ASSUME_DISTID=OEL5withCV_ASSUME_DISTID=OL7.vi cv/admin/cvu_config -
Prepare a
gridsetup.rspfile for silent installation and place the rsp file in the/tmp/archivedirectory. The rsp file should cover sections A, B, and G with the following information:INVENTORY_LOCATION=/u01/app/oraInventory oracle.install.option=HA_CONFIG ORACLE_BASE=/u01/app/oracle oracle.install.asm.OSDBA=asmdba oracle.install.asm.OSOPER=asmoper oracle.install.asm.OSASM=asmadmin oracle.install.asm.SYSASMPassword="SetPWD" oracle.install.asm.diskGroup.name=DATA oracle.install.asm.diskGroup.redundancy=EXTERNAL oracle.install.asm.diskGroup.AUSize=4 oracle.install.asm.diskGroup.disks=/dev/mapper/ora_02_data_01,/dev/mapper/ora_02_data_02,/dev/mapper/ora_02_data_03,/dev/mapper/ora_02_data_04 oracle.install.asm.diskGroup.diskDiscoveryString=/dev/mapper/* oracle.install.asm.monitorPassword="SetPWD" oracle.install.asm.configureAFD=true
Log into the EC2 instance as the root user and set
ORACLE_HOMEandORACLE_BASE.export ORACLE_HOME=/u01/app/oracle/product/19.0.0/export ORACLE_BASE=/tmpcd /u01/app/oracle/product/19.0.0/grid/bin -
Initialize disk devices for use with the Oracle ASM filter driver.
./asmcmd afd_label DATA01 /dev/mapper/ora_02_data_01 --init./asmcmd afd_label DATA02 /dev/mapper/ora_02_data_02 --init./asmcmd afd_label DATA03 /dev/mapper/ora_02_data_03 --init./asmcmd afd_label DATA04 /dev/mapper/ora_02_data_04 --init./asmcmd afd_label LOGS01 /dev/mapper/ora_02_logs_01 --init./asmcmd afd_label LOGS02 /dev/mapper/ora_02_logs_02 --init -
Install
cvuqdisk-1.0.10-1.rpm.rpm -ivh /u01/app/oracle/product/19.0.0/grid/cv/rpm/cvuqdisk-1.0.10-1.rpm -
Unset
$ORACLE_BASE.unset ORACLE_BASE -
Log into the EC2 instance as the Oracle user and extract the patch in the
/tmp/archivefolder.unzip -q /tmp/archive/p34762026_190000_Linux-x86-64.zip -d /tmp/archive -
From grid home /u01/app/oracle/product/19.0.0/grid and as the oracle user, launch
gridSetup.shfor grid infrastructure installation../gridSetup.sh -applyRU /tmp/archive/34762026/ -silent -responseFile /tmp/archive/gridsetup.rsp -
As root user, execute the following script(s):
/u01/app/oraInventory/orainstRoot.sh/u01/app/oracle/product/19.0.0/grid/root.sh -
As root user, reload the multipathd.
As the Oracle user, execute the following command to complete the configuration:
/u01/app/oracle/product/19.0.0/grid/gridSetup.sh -executeConfigTools -responseFile /tmp/archive/gridsetup.rsp -silent -
As the Oracle user, create the LOGS disk group.
bin/asmca -silent -sysAsmPassword 'yourPWD' -asmsnmpPassword 'yourPWD' -createDiskGroup -diskGroupName LOGS -disk 'AFD:LOGS*' -redundancy EXTERNAL -au_size 4 -
As the Oracle user, validate grid services after installation configuration.
bin/crsctl stat res -t[oracle@ora_02 grid]$ bin/crsctl stat res -t -------------------------------------------------------------------------------- Name Target State Server State details -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE ora_02 STABLE ora.LISTENER.lsnr ONLINE INTERMEDIATE ora_02 Not All Endpoints Re gistered,STABLE ora.LOGS.dg ONLINE ONLINE ora_02 STABLE ora.asm ONLINE ONLINE ora_02 Started,STABLE ora.ons OFFLINE OFFLINE ora_02 STABLE -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.cssd 1 ONLINE ONLINE ora_02 STABLE ora.diskmon 1 OFFLINE OFFLINE STABLE ora.driver.afd 1 ONLINE ONLINE ora_02 STABLE ora.evmd 1 ONLINE ONLINE ora_02 STABLE -------------------------------------------------------------------------------- -
Valiate ASM filter driver status.
[oracle@ora_02 grid]$ export ORACLE_HOME=/u01/app/oracle/product/19.0.0/grid [oracle@ora_02 grid]$ export ORACLE_SID=+ASM [oracle@ora_02 grid]$ export PATH=$PATH:$ORACLE_HOME/bin [oracle@ora_02 grid]$ asmcmd ASMCMD> lsdg State Type Rebal Sector Logical_Sector Block AU Total_MB Free_MB Req_mir_free_MB Usable_file_MB Offline_disks Voting_files Name MOUNTED EXTERN N 512 512 4096 4194304 81920 81780 0 81780 0 N DATA/ MOUNTED EXTERN N 512 512 4096 4194304 40960 40852 0 40852 0 N LOGS/ ASMCMD> afd_state ASMCMD-9526: The AFD state is 'LOADED' and filtering is 'ENABLED' on host 'ora_02' ASMCMD> exit [oracle@ora_02 grid]$
Validate HA service status.
[oracle@ora_02 bin]$ ./crsctl check has CRS-4638: Oracle High Availability Services is online
Oracle database installation
Details
Log in as the Oracle user and unset
$ORACLE_HOMEand$ORACLE_SIDif it is set.unset ORACLE_HOMEunset ORACLE_SID -
Create the Oracle DB home directory and change the directory to it.
mkdir /u01/app/oracle/product/19.0.0/cdb3cd /u01/app/oracle/product/19.0.0/cdb3 -
Unzip the Oracle DB installation files.
unzip -q /tmp/archive/LINUX.X64_193000_db_home.zip -
From the DB home, delete the
From DB home, unzip
From DB home, revise
cv/admin/cvu_configand uncomment and replaceCV_ASSUME_DISTID=OEL5withCV_ASSUME_DISTID=OL7.vi cv/admin/cvu_config -
From the
/tmp/archivedirectory, unpack the DB 19.18 RU patch.unzip -q /tmp/archive/p34765931_190000_Linux-x86-64.zip -d /tmp/archive -
Prepare the DB silent install rsp file in
/tmp/archive/dbinstall.rspdirectory with the following values:oracle.install.option=INSTALL_DB_SWONLY UNIX_GROUP_NAME=oinstall INVENTORY_LOCATION=/u01/app/oraInventory ORACLE_HOME=/u01/app/oracle/product/19.0.0/cdb3 ORACLE_BASE=/u01/app/oracle oracle.install.db.InstallEdition=EE oracle.install.db.OSDBA_GROUP=dba oracle.install.db.OSOPER_GROUP=oper oracle.install.db.OSBACKUPDBA_GROUP=oper oracle.install.db.OSDGDBA_GROUP=dba oracle.install.db.OSKMDBA_GROUP=dba oracle.install.db.OSRACDBA_GROUP=dba oracle.install.db.rootconfig.executeRootScript=false
From cdb3 home /u01/app/oracle/product/19.0.0/cdb3, execute silent software-only DB installation.
./runInstaller -applyRU /tmp/archive/34765931/ -silent -ignorePrereqFailure -responseFile /tmp/archive/dbinstall.rsp -
As root user, run the
root.shscript after software-only installation./u01/app/oracle/product/19.0.0/db1/root.sh -
As oracle user, create the
dbca.rspfile with the following entries:gdbName=cdb3.demo.netapp.com sid=cdb3 createAsContainerDatabase=true numberOfPDBs=3 pdbName=cdb3_pdb useLocalUndoForPDBs=true pdbAdminPassword="yourPWD" templateName=General_Purpose.dbc sysPassword="yourPWD" systemPassword="yourPWD" dbsnmpPassword="yourPWD" datafileDestination=+DATA recoveryAreaDestination=+LOGS storageType=ASM diskGroupName=DATA characterSet=AL32UTF8 nationalCharacterSet=AL16UTF16 listeners=LISTENER databaseType=MULTIPURPOSE automaticMemoryManagement=false totalMemory=8192
As oracle user, launch DB creation with dbca.
bin/dbca -silent -createDatabase -responseFile /tmp/archive/dbca.rspoutput:
Prepare for db operation 7% complete Registering database with Oracle Restart 11% complete Copying database files 33% complete Creating and starting Oracle instance 35% complete 38% complete 42% complete 45% complete 48% complete Completing Database Creation 53% complete 55% complete 56% complete Creating Pluggable Databases 60% complete 64% complete 69% complete 78% complete Executing Post Configuration Actions 100% complete Database creation complete. For details check the logfiles at: /u01/app/oracle/cfgtoollogs/dbca/cdb3. Database Information: Global Database Name:cdb3.vmc.netapp.com System Identifier(SID):cdb3 Look at the log file "/u01/app/oracle/cfgtoollogs/dbca/cdb3/cdb3.log" for further details.
Repeat the same procedures from step 2 to create a container database cdb4 in a separate ORACLE_HOME /u01/app/oracle/product/19.0.0/cdb4 with a single PDB.
As Oracle user, validate Oracle Restart HA services after DB creation that all databases (cdb3, cdb4) are registered with HA services.
/u01/app/oracle/product/19.0.0/grid/crsctl stat res -toutput:
[oracle@ora_02 bin]$ ./crsctl stat res -t -------------------------------------------------------------------------------- Name Target State Server State details -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE ora_02 STABLE ora.LISTENER.lsnr ONLINE INTERMEDIATE ora_02 Not All Endpoints Re gistered,STABLE ora.LOGS.dg ONLINE ONLINE ora_02 STABLE ora.asm ONLINE ONLINE ora_02 Started,STABLE ora.ons OFFLINE OFFLINE ora_02 STABLE -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.cdb3.db 1 ONLINE ONLINE ora_02 Open,HOME=/u01/app/o racle/product/19.0.0 /cdb3,STABLE ora.cdb4.db 1 ONLINE ONLINE ora_02 Open,HOME=/u01/app/o racle/product/19.0.0 /cdb4,STABLE ora.cssd 1 ONLINE ONLINE ora_02 STABLE ora.diskmon 1 OFFLINE OFFLINE STABLE ora.driver.afd 1 ONLINE ONLINE ora_02 STABLE ora.evmd 1 ONLINE ONLINE ora_02 STABLE -------------------------------------------------------------------------------- -
Set the Oracle user
.bash_profile.vi ~/.bash_profileAdd following entries:
export ORACLE_HOME=/u01/app/oracle/product/19.0.0/db3 export ORACLE_SID=db3 export PATH=$PATH:$ORACLE_HOME/bin alias asm='export ORACLE_HOME=/u01/app/oracle/product/19.0.0/grid;export ORACLE_SID=+ASM;export PATH=$PATH:$ORACLE_HOME/bin' alias cdb3='export ORACLE_HOME=/u01/app/oracle/product/19.0.0/cdb3;export ORACLE_SID=cdb3;export PATH=$PATH:$ORACLE_HOME/bin' alias cdb4='export ORACLE_HOME=/u01/app/oracle/product/19.0.0/cdb4;export ORACLE_SID=cdb4;export PATH=$PATH:$ORACLE_HOME/bin'
Validate the CDB/PDB created for cdb3.
cdb3[oracle@ora_02 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Mon Oct 9 08:19:20 2023 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- CDB3 READ WRITE SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 CDB3_PDB1 READ WRITE NO 4 CDB3_PDB2 READ WRITE NO 5 CDB3_PDB3 READ WRITE NO SQL> SQL> select name from v$datafile; NAME -------------------------------------------------------------------------------- +DATA/CDB3/DATAFILE/system.257.1149420273 +DATA/CDB3/DATAFILE/sysaux.258.1149420317 +DATA/CDB3/DATAFILE/undotbs1.259.1149420343 +DATA/CDB3/86B637B62FE07A65E053F706E80A27CA/DATAFILE/system.266.1149421085 +DATA/CDB3/86B637B62FE07A65E053F706E80A27CA/DATAFILE/sysaux.267.1149421085 +DATA/CDB3/DATAFILE/users.260.1149420343 +DATA/CDB3/86B637B62FE07A65E053F706E80A27CA/DATAFILE/undotbs1.268.1149421085 +DATA/CDB3/06FB206DF15ADEE8E065025056B66295/DATAFILE/system.272.1149422017 +DATA/CDB3/06FB206DF15ADEE8E065025056B66295/DATAFILE/sysaux.273.1149422017 +DATA/CDB3/06FB206DF15ADEE8E065025056B66295/DATAFILE/undotbs1.271.1149422017 +DATA/CDB3/06FB206DF15ADEE8E065025056B66295/DATAFILE/users.275.1149422033 NAME -------------------------------------------------------------------------------- +DATA/CDB3/06FB21766256DF9AE065025056B66295/DATAFILE/system.277.1149422033 +DATA/CDB3/06FB21766256DF9AE065025056B66295/DATAFILE/sysaux.278.1149422033 +DATA/CDB3/06FB21766256DF9AE065025056B66295/DATAFILE/undotbs1.276.1149422033 +DATA/CDB3/06FB21766256DF9AE065025056B66295/DATAFILE/users.280.1149422049 +DATA/CDB3/06FB22629AC1DFD7E065025056B66295/DATAFILE/system.282.1149422049 +DATA/CDB3/06FB22629AC1DFD7E065025056B66295/DATAFILE/sysaux.283.1149422049 +DATA/CDB3/06FB22629AC1DFD7E065025056B66295/DATAFILE/undotbs1.281.1149422049 +DATA/CDB3/06FB22629AC1DFD7E065025056B66295/DATAFILE/users.285.1149422063 19 rows selected. SQL> -
Validate the CDB/PDB created for cdb4.
cdb4[oracle@ora_02 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Mon Oct 9 08:20:26 2023 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- CDB4 READ WRITE SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 CDB4_PDB READ WRITE NO SQL> SQL> select name from v$datafile; NAME -------------------------------------------------------------------------------- +DATA/CDB4/DATAFILE/system.286.1149424943 +DATA/CDB4/DATAFILE/sysaux.287.1149424989 +DATA/CDB4/DATAFILE/undotbs1.288.1149425015 +DATA/CDB4/86B637B62FE07A65E053F706E80A27CA/DATAFILE/system.295.1149425765 +DATA/CDB4/86B637B62FE07A65E053F706E80A27CA/DATAFILE/sysaux.296.1149425765 +DATA/CDB4/DATAFILE/users.289.1149425015 +DATA/CDB4/86B637B62FE07A65E053F706E80A27CA/DATAFILE/undotbs1.297.1149425765 +DATA/CDB4/06FC3070D5E12C23E065025056B66295/DATAFILE/system.301.1149426581 +DATA/CDB4/06FC3070D5E12C23E065025056B66295/DATAFILE/sysaux.302.1149426581 +DATA/CDB4/06FC3070D5E12C23E065025056B66295/DATAFILE/undotbs1.300.1149426581 +DATA/CDB4/06FC3070D5E12C23E065025056B66295/DATAFILE/users.304.1149426597 11 rows selected. -
Login to each cdb as sysdba with sqlplus and set the DB recovery destination size to the +LOGS disk group size for both cdbs.
alter system set db_recovery_file_dest_size = 40G scope=both; -
Login to each cdb as sysdba with sqlplus and enable archive log mode with following command sets in sequence.
sqlplus /as sysdbashutdown immediate;startup mount;alter database archivelog;alter database open;
This completes Oracle 19c version 19.18 Restart deployment on an Amazon FSx ONTAP storage and a VMC DB VM. If desired, NetApp recommends relocating the Oracle control file and online log files to the +LOGS disk group.
Oracle backup, restore, and clone with SnapCenter
SnapCenter Setup
Details
SnapCenter relies on a host-side plug-in on database VM to perform application-aware data protection management activities. For detailed information on NetApp SnapCenter plugin for Oracle, refer to this documentation What can you do with the Plug-in for Oracle Database. The following provides high level steps to setup SnapCenter for Oracle database backup, recovery, and clone.
Download the latest version of SnapCenter software from NetApp support site: NetApp Support Downloads.
As administrator, install latest java JDK from Get Java for desktop applications on SnapCenter server Windows host.
If Windows server is deployed in a domain environment, add a domain user to SnapCenter server local administrators group and run SnapCenter installation with the domain user. -
Login to SnapCenter UI via HTTPS port 8846 as installation user to configure SnapCenter for Oracle.
Update
Hypervisor Settingsin global settings.
Create Oracle database backup policies. Ideally, create a separate archive log backup policy to allow more frequent backup interval to minimize data loss in the event of a failure.
Add database server
Credentialfor SnapCenter access to DB VM. The credential should have sudo privilege on a Linux VM or administrator privilege on a Windows VM.
Add FSx ONTAP storage cluster to
Storage Systemswith cluster management IP and authenticated via fsxadmin user ID.
Add Oracle database VM in VMC to
Hostswith server credential created in previous step 6.
Ensure that the SnapCenter server name can be resolved to the IP address from the DB VM and DB VM name can be resolved to the IP address from the SnapCenter server. |
Database backup
Details
SnapCenter leverages FSx ONTAP volume snapshot for much quicker database backup, restore, or clone compared with traditional RMAN based methodology. The snapshots are application-consistent as the database is put in Oracle backup mode before a snapshot.
From the
Resourcestab, any databases on the VM are auto-discovered after the VM is added to SnapCenter. Initially, the database status shows asNot protected.
Create a resources group to backup the database in a logical grouping such as by DB VM etc. In this example, we created an ora_02_data group to do a full online database backup for all databases on VM ora_02. Resources group ora_02_log performs the backup of archived logs only on the VM. Creating a resources group also defines a schedule to execute the backup.
Resources group backup can also be triggered manually by clicking on
Back up Nowand executing the backup with the policy defined in the resources group.
The backup job can be monitored at the
Monitortab by clicking on the running job.
After a successful backup, the database status shows the job status and the most recent backup time.
Click on database to review the backup sets for each database.
Database recovery
Details
SnapCenter provides a number of restore and recovery options for Oracle databases from snapshot backup. In this example, we demonstrate a point in time restoration to recover a dropped table by mistake. On VM ora_02, two databases cdb3, cdb4 share the same +DATA and +LOGS disk groups. Database restoration for one database does not impact the availability of the other database.
First, create a test table and insert a row into table to validate a point in time recovery.
[oracle@ora_02 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Fri Oct 6 14:15:21 2023 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- CDB3 READ WRITE SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 CDB3_PDB1 READ WRITE NO 4 CDB3_PDB2 READ WRITE NO 5 CDB3_PDB3 READ WRITE NO SQL> SQL> alter session set container=cdb3_pdb1; Session altered. SQL> create table test (id integer, dt timestamp, event varchar(100)); Table created. SQL> insert into test values(1, sysdate, 'test oracle recovery on guest mounted fsx storage to VMC guest vm ora_02'); 1 row created. SQL> commit; Commit complete. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 06-OCT-23 03.18.24.000000 PM test oracle recovery on guest mounted fsx storage to VMC guest vm ora_02 SQL> select current_timestamp from dual; CURRENT_TIMESTAMP --------------------------------------------------------------------------- 06-OCT-23 03.18.53.996678 PM -07:00 -
We run a manual snapshot backup from SnapCenter. Then drop the table.
SQL> drop table test; Table dropped. SQL> commit; Commit complete. SQL> select current_timestamp from dual; CURRENT_TIMESTAMP --------------------------------------------------------------------------- 06-OCT-23 03.26.30.169456 PM -07:00 SQL> select * from test; select * from test * ERROR at line 1: ORA-00942: table or view does not exist -
From backup set created from last step, take a note of the SCN number of log backup. Click on
Restoreto launch restore-recover workflow.
Choose restore scope.
Choose recovery scope up to the log SCN from last full database backup.
Specify any optional pre-scripts to run.
Specify any optional after-script to run.
Send a job report if desired.
Review the summary and click on
Finishto launch the restoration and recovery.
From Oracle Restart grid control, we observe that while cdb3 is under restoration and recovery cdb4 is online and available.
From
Monitortab, open the job to review the details.
From DB VM ora_02, validate the dropped table is recovered after a successful recovery.
[oracle@ora_02 bin]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Fri Oct 6 17:01:28 2023 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- CDB3 READ WRITE SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 CDB3_PDB1 READ WRITE NO 4 CDB3_PDB2 READ WRITE NO 5 CDB3_PDB3 READ WRITE NO SQL> alter session set container=CDB3_PDB1; Session altered. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 06-OCT-23 03.18.24.000000 PM test oracle recovery on guest mounted fsx storage to VMC guest vm ora_02 SQL> select current_timestamp from dual; CURRENT_TIMESTAMP --------------------------------------------------------------------------- 06-OCT-23 05.02.20.382702 PM -07:00 SQL>
Database clone
Details
In this example, the same backup sets is used to clone a database on the same VM in a different ORACLE_HOME. The procedures are equally applicable to clone a database from the backup to separate VM in VMC if needed.
Open the database cdb3 backup list. From a data backup of choice, click on
Clonebutton to launch database clone workflow.
Name the clone database SID.
Select a VM in VMC as the target database host. Identical Oracle version should have been installed and configured on the host.
Select the proper ORACLE_HOME, user and group on the target host. Keep credential at default.
Change clone database parameters to meet configuration or resources requirements for the clone database.
Choose recovery scope.
Until Cancelrecovers the clone up to last available log file in the backup set.
Review the summary and launch the clone job.
Monitor the clone job execution from
Monitortab.
Cloned database is immediately registered in SnapCenter.
From DB VM ora_02, the cloned database is also registered in Oracle Restart grid control and the dropped test table is recovered in the cloned database cdb3tst as shown below.
[oracle@ora_02 ~]$ /u01/app/oracle/product/19.0.0/grid/bin/crsctl stat res -t -------------------------------------------------------------------------------- Name Target State Server State details -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE ora_02 STABLE ora.LISTENER.lsnr ONLINE INTERMEDIATE ora_02 Not All Endpoints Re gistered,STABLE ora.LOGS.dg ONLINE ONLINE ora_02 STABLE ora.SC_2090922_CDB3TST.dg ONLINE ONLINE ora_02 STABLE ora.asm ONLINE ONLINE ora_02 Started,STABLE ora.ons OFFLINE OFFLINE ora_02 STABLE -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.cdb3.db 1 ONLINE ONLINE ora_02 Open,HOME=/u01/app/o racle/product/19.0.0 /cdb3,STABLE ora.cdb3tst.db 1 ONLINE ONLINE ora_02 Open,HOME=/u01/app/o racle/product/19.0.0 /cdb4,STABLE ora.cdb4.db 1 ONLINE ONLINE ora_02 Open,HOME=/u01/app/o racle/product/19.0.0 /cdb4,STABLE ora.cssd 1 ONLINE ONLINE ora_02 STABLE ora.diskmon 1 OFFLINE OFFLINE STABLE ora.driver.afd 1 ONLINE ONLINE ora_02 STABLE ora.evmd 1 ONLINE ONLINE ora_02 STABLE -------------------------------------------------------------------------------- [oracle@ora_02 ~]$ export ORACLE_HOME=/u01/app/oracle/product/19.0.0/cdb4 [oracle@ora_02 ~]$ export ORACLE_SID=cdb3tst [oracle@ora_02 ~]$ sqlplus / as sysdba SQL*Plus: Release 19.0.0.0.0 - Production on Sat Oct 7 08:04:51 2023 Version 19.18.0.0.0 Copyright (c) 1982, 2022, Oracle. All rights reserved. Connected to: Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.18.0.0.0 SQL> select name, open_mode from v$database; NAME OPEN_MODE --------- -------------------- CDB3TST READ WRITE SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 CDB3_PDB1 READ WRITE NO 4 CDB3_PDB2 READ WRITE NO 5 CDB3_PDB3 READ WRITE NO SQL> alter session set container=CDB3_PDB1; Session altered. SQL> select * from test; ID ---------- DT --------------------------------------------------------------------------- EVENT -------------------------------------------------------------------------------- 1 06-OCT-23 03.18.24.000000 PM test oracle recovery on guest mounted fsx storage to VMC guest vm ora_02 SQL>
This completes the demonstration of SnapCenter backup, restore, and clone of Oracle database in VMC SDDC on AWS.
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
VMware Cloud on AWS Documentation
Installing Oracle Grid Infrastructure for a Standalone Server with a New Database Installation
Installing and Configuring Oracle Database Using Response Files
Amazon FSx ONTAP
