SnapCenter software
What can you do with the Plug-in for Oracle Database
Contributors netapp-soumikd netapp-asubhas
The SnapCenter Plug-in for Oracle Database is a host-side component of the NetApp SnapCenter Software that enables application-aware data protection management of Oracle databases.
The Plug-in for Oracle Database automates the backup, cataloging and uncataloging with Oracle Recovery Manager (RMAN), verification, mounting, unmounting, restore, recovery, and cloning of Oracle databases in your SnapCenter environment. The Plug-in for Oracle Database installs SnapCenter Plug-in for UNIX to perform all the data protection operations.
You can use the Plug-in for Oracle Database to manage backups of Oracle databases running SAP applications. However, SAP BR*Tools integration is not supported.
  • Back up datafiles, control files, and archive log files.
    Backup is supported only at container database (CDB) level.
  • Restore and recovery of databases, CDBs, and pluggable databases (PDBs).
    Incomplete recovery of PDBs are not supported.
  • Create clones of production databases up to a point-in-time.
    Cloning is supported only at CDB level.
  • Verify backups immediately.
  • Mount and unmount data and log backups for recovery operation.
  • Schedule backup and verification operations.
  • Monitor all operations.
  • View reports for backup, restore, and clone operations.
  • Automates application-aware backup, restore, recovery, verify, mount, unmount, and clone operations for Oracle databases in your SnapCenter environment
  • Supports Oracle databases for SAP, however, SAP BR*Tools integration is not provided
