SnapCenter software
Learn about NetApp supported plug-ins in SnapCenter
Contributors netapp-nsriram
You can use the NetApp supported plug-ins like MongoDB, ORASCPM, Oracle Applications, SAP ASE, SAP MaxDB, and Storage plug-in for data protection operations.
  • Add resources such as databases, instances, documents, or tablespaces.
  • Create backups.
  • Restore from backups.
  • Clone backups.
  • Schedule backup operations.
  • Monitor backup, restore, and clone operations.
  • View reports for backup, restore, and clone operations.
You can use the NetApp supported plug-ins for data protection operations.
  • Take consistency group Snapshots of the storage volumes across ONTAP clusters.
  • Backup custom applications using the built in pre and post scripting framework
    You can backup ONTAP volume, LUN, or a Qtree.
  • Update Snapshots taken on the primary to an ONTAP secondary, leveraging the existing replication relationship (SnapVault/SnapMirror/unified replication) using SnapCenter policy
    ONTAP primary and secondary can be ONTAP FAS, AFF, ASA, ONTAP Select, or Cloud Volumes ONTAP.
  • Recover complete ONTAP volume, LUN, or files.
    You should provide the respective file path manually as the browse or indexing features are not built into the product.
    Qtree or directory restore is not supported but you can clone and export only the Qtree if the backup scope is defined at a Qtree level.
