SnapCenter software
Upgrade paths for SnapCenter
Contributors netapp-yvonneo netapp-soumikd
The upgrade path shows which SnapCenter versions you can upgrade from and which plug-in versions are supported.
Note If you upgrade SnapCenter Server to 6.2, also upgrade the plug-ins to 6.2.
NetApp recommends upgrading to the latest supported SnapCenter version, 6.2.3, to ensure compatibility and optimal performance with SnapCenter.
Caution To upgrade to SnapCenter 6.2.3 from a version earlier than 6.0 or from 6.0, first upgrade to 6.1P3, which supports .NET 8 and Java 11, and then upgrade to 6.2.3, which supports .NET 10 and Java 17. Do not use 6.2.2 or any other intermediate version as part of the upgrade path unless you are already using it.
Refer to Upgrade Hosts to SnapCenter 6.2.3 in the SnapCenter Release Notes for further details on upgrading your hosts.
Supported upgrade paths
If you are on SnapCenter Server version…​ You can directly upgrade SnapCenter Server to…​ Supported plug-in versions
6.0.1
6.1
  • 6.0.1
  • 6.1
6.2
  • 6.2
6.2.1
  • 6.2.1
6.2.2
  • 6.2.2
6.1
6.2
  • 6.1
  • 6.2
6.2.1
  • 6.2.1
6.2.2
  • 6.2.2
6.2.3
  • 6.2.2
  • 6.2.3
6.2
6.2.1
  • 6.2
6.2.2
  • 6.2
6.2.3
  • 6.2.2
  • 6.2.3
For information about upgrading the SnapCenter Plug-in for VMware vSphere, see Upgrade SnapCenter Plug-in for VMware vSphere.
