SnapCenter software
Supported Oracle database configurations for backups in SnapCenter
Contributors netapp-soumikd netapp-nsriram netapp-jsnyder
SnapCenter supports backup of different Oracle database configurations.
  • Oracle Standalone
  • Oracle Real Application Clusters (RAC)
  • Oracle Standalone Legacy
  • Oracle Standalone Container Database (CDB)
  • Oracle Data Guard standby
    You can only create offline-mount backups of Data Guard standby databases. Offline-shutdown backup, archive log only backup, and full backup are not supported.
  • Oracle Active Data Guard standby
    You can only create online backups of Active Data Guard standby databases. Archive log only backup and full backup are not supported.
    Before creating a backup of Data Guard standby or Active Data Guard standby database, the managed recovery process (MRP) is stopped and once the backup is created, MRP is started.
  • Automatic Storage Management (ASM)
    • ASM standalone and ASM RAC on Virtual Machine Disk (VMDK)
      Among all the restore methods supported for Oracle databases, you can perform only connect-and-copy restore of ASM RAC databases on VMDK.
    • ASM standalone and ASM RAC on Raw device mapping (RDM)
      You can perform backup, restore, and clone operations on Oracle databases on ASM, with or without ASMLib.
    • Oracle ASM Filter Driver (ASMFD)
      PDB migration and PDB cloning operations are not supported.
    • Oracle Flex ASM
For the latest information about supported Oracle versions, see the NetApp Interoperability Matrix Tool.
