SnapCenter software
SnapCenter Plug-in for IBM Db2 restore workflow
Contributors netapp-nsriram netapp-soumikd
The restore and recovery workflow includes planning, performing the restore operations, and monitoring the operations.
The following workflow shows the sequence in which you must perform the restore operation:
Restore workflow
You can also use PowerShell cmdlets manually or in scripts to perform backup, restore, and clone operations. The SnapCenter cmdlet help and the cmdlet reference information contain detailed information about PowerShell cmdlets.
