SnapCenter prescript and postscript environment variables for backup
SnapCenter allows you to use the predefined environment variables when you execute the prescript and postscript while creating backup policies. This functionality is supported for all Oracle configurations except for VMDK.
SnapCenter predefines the values of the parameters that will be directly accessible in the environment where the shell scripts are executed. You do not have to manually specify the values of these parameters when executing the scripts.
Supported predefined environment variables for creating backup policy
SC_JOB_ID specifies the job ID of the operation.
Example: 256
SC_ORACLE_SID specifies the system identifier of the database.
If the operation involves multiple databases, the parameter will contain database names separated by pipe.
This parameter will be populated for application volumes.
Example: NFSB32|NFSB31
SC_HOST specifies the host name of the database.
For RAC, host name will be the name of the host on which backup is performed.
Example: scsmohost2.gdl.englabe.netapp.com
SC_OS_USER specifies the operating system owner of the database.
The data will be formatted as <db1>@<osuser1>|<db2>@<osuser2>.
Example: NFSB31@oracle|NFSB32@oracle
SC_OS_GROUP specifies the operating system group of the database.
The data will be formatted as <db1>@<osgroup1>|<db2>@<osgroup2>.
Example: NFSB31@install|NFSB32@oinstall
SC_BACKUP_TYPE" specifies the backup type (online full, online data, online log, offline shutdown, offline mount)
Examples:
For full backup: ONLINEFULL
data only backup: ONLINEDATA
For log only backup: ONLINELOG
SC_BACKUP_NAME specifies the name of the backup.
Example: DATA@RG2_scspr2417819002_07-20-2021_12.16.48.9267_0|LOG@RG2_scspr2417819002_07-20-2021_12.16.48.9267_1|AV@RG2_scspr2417819002_07-20-2021_12.16.48.9267
SC_BACKUP_ID specifies the backup ID.
Example: DATA@203|LOG@205|AV@207
SC_ORACLE_HOME specifies the path of the Oracle home directory.
Example: NFSB32@/ora01/app/oracle/product/18.1.0/db_1|NFSB31@/ora01/app/oracle/product/18.1.0/db_1
SC_BACKUP_RETENTION specifies the retention period defined in the policy.
Examples:
For full backup: Hourly|DATA@DAYS:3|LOG@COUNT:4
For on-demand data only backup: Ondemand|DATA@COUNT:2
For on-demand log only backup: Ondemand|LOG@COUNT:2
SC_RESOURCE_GROUP_NAME specifies the name of the resource group.
Example: RG1
SC_BACKUP_POLICY_NAME specifies the name of the backup policy.
Example: backup_policy
SC_AV_NAME specifies the names of the application volumes.
Example: AV1|AV2
SC_PRIMARY_DATA_VOLUME_FULL_PATH specifies the storage mapping of SVM to volume for data files directory. It will be the name of the parent volume for luns and qtrees.
The data will be formatted as <db1>@<SVM1:volume1>|<db2>@<SVM2:volume2>.
Examples:
For 2 databases in the same resource group: NFSB32@buck:/vol/scspr2417819002_NFS_CDB_NFSB32_DATA|NFSB31@buck:/vol/scspr2417819002_NFS_CDB_NFSB31_DATA
For single database with data files spread across multiple volumes: buck:/vol/scspr2417819002_NFS_CDB_NFSB31_DATA,herculus:/vol/scspr2417819002_NFS
SC_PRIMARY_ARCHIVELOGS_VOLUME_FULL_PATH specifies the storage mapping of SVM to volume for logs file directory. It will be the name of the parent volume for luns and qtrees.
Examples:
For single database instance: buck:/vol/scspr2417819002_NFS_CDB_NFSB31_REDO
For multiple database instances: NFSB31@buck:/vol/scspr2417819002_NFS_CDB_NFSB31_REDO|NFSB32@buck:/vol/scspr2417819002_NFS_CDB_NFSB32_REDO
SC_PRIMARY_FULL_SNAPSHOT_NAME_FOR_TAG specifies the list of Snapshots containing storage system name and volume name.
Examples:
For single database instance: buck:/vol/scspr2417819002_NFS_CDB_NFSB32_DATA/RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,buck:/vol/scspr2417819002_NFS_CDB_NFSB32_REDO/RG2_scspr2417819002_07-21-2021_02.28.26.3973_1
For multiple database instances: NFSB32@buck:/vol/scspr2417819002_NFS_CDB_NFSB32_DATA/RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,buck:/vol/scspr2417819002_NFS_CDB_NFSB32_REDO/RG2_scspr2417819002_07-21-2021_02.28.26.3973_1|NFSB31@buck:/vol/scspr2417819002_NFS_CDB_NFSB31_DATA/RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,buck:/vol/scspr2417819002_NFS_CDB_NFSB31_REDO/RG2_scspr2417819002_07-21-2021_02.28.26.3973_1
SC_PRIMARY_SNAPSHOT_NAMES specifies the names of the primary Snapshots created during the backup.
Examples:
For single database instance: RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,RG2_scspr2417819002_07-21-2021_02.28.26.3973_1
For multiple database instances: NFSB32@RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,RG2_scspr2417819002_07-21-2021_02.28.26.3973_1|NFSB31@RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,RG2_scspr2417819002_07-21-2021_02.28.26.3973_1
For consistency group Snapshots that involves 2 volumes: cg3_R80404CBEF5V1_04-05-2021_03.08.03.4945_0_bfc279cc-28ad-465c-9d60-5487ac17b25d_2021_4_5_3_8_58_350
SC_PRIMARY_MOUNT_POINTS specifies the mount point details which are part of the backup.
The details include the directory on which volumes are mounted and not the immediate parent of the file under backup. For an ASM configuration, it is the name of the disk group.
The data will be formatted as <db1>@<mountpoint1,mountpoint2>|<db2>@<mountpoint1,mountpoint2>.
Examples:
For single database instance: /mnt/nfsdb3_data,/mnt/nfsdb3_log,/mnt/nfsdb3_data1
For multiple database instances: NFSB31@/mnt/nfsdb31_data,/mnt/nfsdb31_log,/mnt/nfsdb31_data1|NFSB32@/mnt/nfsdb32_data,/mnt/nfsdb32_log,/mnt/nfsdb32_data1
For ASM: +DATA2DG,+LOG2DG
SC_PRIMARY_SNAPSHOTS_AND_MOUNT_POINTS specifies the names of the snapshots created during the backup of each of the mount points.
Examples:
For single database instance: RG2_scspr2417819002_07-21-2021_02.28.26.3973_0:/mnt/nfsb32_data,RG2_scspr2417819002_07-21-2021_02.28.26.3973_1:/mnt/nfsb31_log
For multiple database instances: NFSB32@RG2_scspr2417819002_07-21-2021_02.28.26.3973_0:/mnt/nfsb32_data,RG2_scspr2417819002_07-21-2021_02.28.26.3973_1:/mnt/nfsb31_log|NFSB31@RG2_scspr2417819002_07-21-2021_02.28.26.3973_0:/mnt/nfsb31_data,RG2_scspr2417819002_07-21-2021_02.28.26.3973_1:/mnt/nfsb32_log
SC_ARCHIVELOGS_LOCATIONS specifies the location of the archive logs directory.
The directory names will be the immediate parent of the archive log files. If the archive logs are placed in more than one location then all the locations will be captured. This also includes the FRA scenarios. If softlinks are used for directory then the same will be populated.
Examples:
For single database on NFS: /mnt/nfsdb2_log
For multiple databases on NFS and for the NFSB31 database archive logs that are placed in two different locations: NFSB31@/mnt/nfsdb31_log1,/mnt/nfsdb31_log2|NFSB32@/mnt/nfsdb32_log
For ASM: +LOG2DG/ASMDB2/ARCHIVELOG/2021_07_15
SC_REDO_LOGS_LOCATIONS specifies the location of the redo logs directory.
The directory names will be the immediate parent of the redo log files. If softlinks are used for directory then the same will be populated.
Examples:
For single database on NFS: /mnt/nfsdb2_data/newdb1
For multiple databases on NFS: NFSB31@/mnt/nfsdb31_data/newdb31|NFSB32@/mnt/nfsdb32_data/newdb32
For ASM: +LOG2DG/ASMDB2/ONLINELOG
SC_CONTROL_FILES_LOCATIONS specifies the location of the control files directory.
The directory names will be the immediate parent of the control files. If softlinks are used for directory then the same will be populated.
Examples:
For single database on NFS: /mnt/nfsdb2_data/fra/newdb1,/mnt/nfsdb2_data/newdb1
For multiple databases on NFS: NFSB31@/mnt/nfsdb31_data/fra/newdb31,/mnt/nfsdb31_data/newdb31|NFSB32@/mnt/nfsdb32_data/fra/newdb32,/mnt/nfsdb32_data/newdb32
For ASM: +LOG2DG/ASMDB2/CONTROLFILE
SC_DATA_FILES_LOCATIONS" specifies the location of the data files directory.
The directory names will be the immediate parent of the data files. If softlinks are used for directory then the same will be populated.
Examples:
For single database on NFS: /mnt/nfsdb3_data1,/mnt/nfsdb3_data/NEWDB3/datafile
For multiple databases on NFS: NFSB31@/mnt/nfsdb31_data1,/mnt/nfsdb31_data/NEWDB31/datafile|NFSB32@/mnt/nfsdb32_data1,/mnt/nfsdb32_data/NEWDB32/datafile
For ASM: +DATA2DG/ASMDB2/DATAFILE,+DATA2DG/ASMDB2/TEMPFILE
SC_SNAPSHOT_LABEL specifies the name of the secondary labels.
Examples: Hourly, Daily, Weekly, Monthly, or custom label.
Supported delimiters
: is used to separate SVM name and volume name
Example: buck:/vol/scspr2417819002_NFS_CDB_NFSB32_DATA/RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,buck:/vol/scspr2417819002_NFS_CDB_NFSB32_REDO/RG2_scspr2417819002_07-21-2021_02.28.26.3973_1
@ is used to separate data from its database name and to separate the value from its key.
Examples:
| is used to separate the data between two different databases and to separate the data between two different entities for SC_BACKUP_ID, SC_BACKUP_RETENTION, and SC_BACKUP_NAME parameters.
Examples:
DATA@203|LOG@205
/ is used to separate the volume name from it's Snapshot for SC_PRIMARY_SNAPSHOT_NAMES and SC_PRIMARY_FULL_SNAPSHOT_NAME_FOR_TAG parameters.
Example: NFSB32@buck:/vol/scspr2417819002_NFS_CDB_NFSB32_DATA/RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,buck:/vol/scspr2417819002_NFS_CDB_NFSB32_REDO/RG2_scspr2417819002_07-21-2021_02.28.26.3973_1
, is used to separate set of variables for the same DB.
Example: NFSB32@buck:/vol/scspr2417819002_NFS_CDB_NFSB32_DATA/RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,buck:/vol/scspr2417819002_NFS_CDB_NFSB32_REDO/RG2_scspr2417819002_07-21-2021_02.28.26.3973_1|NFSB31@buck:/vol/scspr2417819002_NFS_CDB_NFSB31_DATA/RG2_scspr2417819002_07-21-2021_02.28.26.3973_0,buck:/vol/scspr2417819002_NFS_CDB_NFSB31_REDO/RG2_scspr2417819002_07-21-2021_02.28.26.3973_1
