Prerequisites for adding hosts and installing the SnapCenter Plug-ins Package for Linux
Before you add a host and install the plug-ins package for Linux, you must complete all the requirements.
If you are using iSCSI, the iSCSI service must be running.
You can either use the password-based authentication for the root or non-root user or SSH key based authentication.
The RSA key is the only SSH supported key format for SnapCenter. Refer to the Knowledge Base article How to create an RSA key for SnapCenter SSH Key Based credential for details on how to create the SSH key. SnapCenter Plug-in for Unix File Systems can be installed by a non-root user. However, you should configure the sudo privileges for the non-root user to install and start the plug-in process. After installing the plug-in, the processes will be running as an effective non-root user.
Create credentials with authentication mode as Linux for the install user.
You must have installed Java 17 for SnapCenter 6.2.1 and later or Java 11 for SnapCenter 6.2 and earlier on your Linux host.
Ensure that you have installed only the certified edition of Java 17 for SnapCenter 6.2.1 and later or Java 11 for SnapCenter 6.2 and earlier on the Linux host. For information on Java downloads, refer to Download Java for all operating systems.
You should have bash as the default shell for plug-in installation.
Linux Host requirements
You should ensure that the host meets the requirements before installing the SnapCenter Plug-ins Package for Linux.
| Item | Requirements | ||||
Operating systems |
Minimum RAM for the SnapCenter plug-in on host |
2 GB |
Minimum install and log space for the SnapCenter plug-in on host |
2 GB
Required software packages |
For the latest information about supported versions, see the NetApp Interoperability Matrix Tool.
