Prepare for Snapcenter Server and Plug-in installation
Provides a condensed set of preparation instructions for installing the SnapCenter Server and the SnapCenter Plug-in for Microsoft SQL Server.
Domain and workgroup requirements
SnapCenter Server can be installed on systems that are either in a domain or in a workgroup.
If you are using an Active Directory domain, you should use a Domain user with local administrator rights. The Domain user should be a member of the local Administrator group on the Windows host.
If you are using workgroups, you should use a local account that has local administrator rights.
License requirements
The type of licenses you install depends on your environment.
License | Where required | ||
SnapCenter Standard controller-based |
Required for FAS or AFF storage controllers SnapCenter Standard license is a controller-based license and is included as part of the premium bundle. If you have the SnapManager Suite license, you also get the SnapCenter Standard license entitlement. If you want to install SnapCenter on a trial basis with FAS or AFF storage, you can obtain a Premium Bundle evaluation license by contacting the sales representative. |
SnapMirror or SnapVault |
ONTAP Either SnapMirror or SnapVault license is required if replication is enabled in SnapCenter. |
Additional licenses (optional) |
See SnapCenter licenses. |
SnapCenter Standard licenses (optional) |
Secondary destinations
Host and port requirements
For ONTAP and application plug-in minimum requirements see Interoperability Matrix Tool.
Hosts | Minimum requirements |
Operating System (64-bit) |
CPU |
RAM |
Hard drive space |
Server host:
Third-party libraries |
Required on SnapCenter Server host and plug-in host:
Browsers |
Chrome, Internet Explorer, and Microsoft Edge |
Port type | Default port |
SnapCenter port |
8146 (HTTPS), bidirectional, customizable, as in the URL https://server:8146 |
SnapCenter SMCore communication port |
8145 (HTTPS), bidirectional, customizable |
Repository database |
3306 (HTTPS), bidirectional |
Windows plug-in hosts |
135, 445 (TCP) In addition to ports 135 and 445, the dynamic port range specified by Microsoft should also be open. Remote install operations use the Windows Management Instrumentation (WMI) service, which dynamically searches this port range. For information on the dynamic port range supported, see Service overview and network port requirements for Windows. |
SnapCenter Plug-in for Windows |
ONTAP cluster or SVM communication port |
443 (HTTPS), bidirectional; 80 (HTTP), bidirectional The port is used for communication between the SnapCenter Server host, plug-in host, and SVM or ONTAP Cluster. |
SnapCenter Plug-in for Microsoft SQL Server requirements
You should have a user with local administrator privileges with local login permissions on the remote host. If you manage cluster nodes, you need a user with administrative privileges to all the nodes in the cluster.
You should have a user with sysadmin permissions on the SQL Server. The plug-in uses Microsoft VDI Framework, which requires sysadmin access.
If you were using SnapManager for Microsoft SQL Server and want to import data from SnapManager for Microsoft SQL Server to SnapCenter, see Import archived backups
