SnapCenter software
Learn about the SnapCenter Plug-in for PostgreSQL
Contributors netapp-nsriram netapp-soumikd
The SnapCenter Plug-in for PostgreSQL cluster is a host-side component of the NetApp SnapCenter software that enables application-aware data protection management of PostgreSQL clusters. The Plug-in for PostgreSQL cluster automates the backup, restore, and cloning of PostgreSQL clusters in your SnapCenter environment.
SnapCenter supports single cluster and multi cluster PostgreSQL setups. You can use the Plug-in for PostgreSQL Clusters in both Linux and Windows environments. In Windows environments, PostgreSQL will be supported as manual resource.
When the Plug-in for PostgreSQL cluster is installed, you can use SnapCenter with NetApp SnapMirror technology to create mirror copies of backup sets on another volume. You can also use the plug-in with NetApp SnapVault technology to perform disk-to-disk backup replication for standards compliance.
SnapCenter Plug-in for PostgreSQL supports NFS and SAN on ONTAP and Azure NetApp File storage layouts.
VMDK, vVol, and RDM virtual storage layout is supported.
