SnapCenter software
Define a restore and recovery strategy for MySQL resources with SnapCenter
Contributors netapp-nsriram
You must define a strategy before you restore and recover your database so that you can perform restore and recovery operations successfully.
Note Only manual recovery of database is supported.
Steps
  1. Determine the restore strategies supported for manually added MySQL resources
  2. Determine the restore strategies supported for auto discovered MySQL databases
  3. Decide the type of recovery operations that you want to perform.
