Define a restore and recovery strategy for MySQL resources
You must define a strategy before you restore and recover your database so that you can perform restore and recovery operations successfully.
Only manual recovery of database is supported. |
Steps
Determine the restore strategies supported for manually added MySQL resources
Determine the restore strategies supported for auto discovered MySQL databases
Decide the type of recovery operations that you want to perform.
