SnapCenter software
Delete or split IBM Db2 database clones after upgrading SnapCenter
Contributors netapp-soumikd netapp-nsriram
After upgrading to SnapCenter 4.3, you will no longer see the clones. You can delete the clone or split the clones from the Topology page of the resource from which the clones were created.
About this task
If you want to locate the storage footprint of the hidden clones, run the following command: Get-SmClone -ListStorageFootprint
Steps
  1. Delete the backups of the cloned resources by using the remove-smbackup cmdlet.
  2. Delete the resource group of the cloned resources by using the remove-smresourcegroup cmdlet.
  3. Remove the protection of the cloned resource by using the remove-smprotectresource cmdlet.
  4. Select the parent resource from the Resources page.
    The resource topology page is displayed.
  5. From the Manage Copies view, select the clones either from the primary or secondary (mirrored or replicated) storage systems.
  6. Select the clones, and then click delete icon to delete clones or click split clone to split the clones.
  7. Click OK.
