SnapCenter software
Prerequisites to use the SnapCenter Plug-in for MySQL
Contributors netapp-yvonneo netapp-nsriram
Before you use SnapCenter Plug-in for MySQL, the SnapCenter administrator must install and configure the SnapCenter Server and perform the prerequisite tasks.
  • Install and configure SnapCenter Server.
  • Log in to SnapCenter Server.
  • Configure the SnapCenter environment by adding storage system connections and creating credentials, if applicable.
  • Install Java 17 (Oracle Java, OpenJDK, or SAP JDK) for SnapCenter 6.2.1 and later or Java 11 for SnapCenter 6.2 and earlier on your Linux or Windows host.
    Note Non-root users must have execute permissions to run Java.
    You must set the Java path in the environmental path variable of the host machine.
  • Set up SnapMirror and SnapVault, if you want backup replication.
