SnapCenter software
Set up credentials to use the SnapCenter Plug-in for PostgreSQL
Contributors netapp-nsriram
SnapCenter uses credentials to authenticate users for SnapCenter operations. You should create credentials for installing SnapCenter plug-ins and additional credentials for performing data protection operations on clusters or Windows file systems.
About this task
  • Linux hosts
    You must set up credentials for installing plug-ins on Linux hosts.
    You must set up the credentials for the root user or for a non-root user who has sudo privileges to install and start the plug-in process.
    Best Practice: Although you are allowed to create credentials for Linux after deploying hosts and installing plug-ins, the best practice is to create credentials after you add SVMs, before you deploy hosts and install plug-ins.
  • Windows hosts
    You must set up Windows credentials before installing plug-ins.
    You must set up the credentials with administrator privileges, including administrator rights on the remote host.
If you set up credentials for individual resource groups and the username does not have full admin privileges, you must assign at least the resource group and backup privileges to the username.
Steps
  1. In the left navigation pane, click Settings.
  2. In the Settings page, click Credential.
  3. Click New.
  4. In the Credential page, specify the information required for configuring credentials:
    For this field…​ Do this…​
    Credential name
    Enter a name for the credentials.
    User name
    Enter the user name and password that are to be used for authentication.
    • Domain administrator or any member of the administrator group
      Specify the domain administrator or any member of the administrator group on the system on which you are installing the SnapCenter plug-in. Valid formats for the Username field are:
      • NetBIOS\UserName
      • Domain FQDN\UserName
    • Local administrator (for workgroups only)
      For systems that belong to a workgroup, specify the built-in local administrator on the system on which you are installing the SnapCenter plug-in. You can specify a local user account that belongs to the local administrators group if the user account has elevated privileges or the User Access control feature is disabled on the host system. The valid format for the Username field is: UserName
      Do not use double quotes (") or backtick (`) in the passwords. You should not use the less than (<) and exclamation (!) symbols together in passwords. For example, lessthan<!10, lessthan10<!, backtick`12.
    Password
    Enter the password used for authentication.
    Authentication Mode
    Select the authentication mode that you want to use.
    Use sudo privileges
    Select the Use sudo privileges check box if you are creating credentials for a non-root user.
    Note Applicable to Linux users only.
  5. Click OK.
After you finish setting up the credentials, you might want to assign credential maintenance to a user or group of users in the User and Access page.
