Host requirements for installing the SnapCenter Plug-ins Package for Linux and AIX
You should ensure that the host meets the requirements before installing the SnapCenter Plug-ins Package for Linux or AIX.
Storage and Oracle applications are supported on AIX. |
| Item | Requirements | ||
Operating systems |
Minimum RAM for the SnapCenter plug-in on host |
1 GB |
Minimum install and log space for the SnapCenter plug-in on host |
2 GB
Required software packages |
Java 11 Oracle Java or OpenJDK If you have upgraded JAVA to the latest version, you must ensure that the JAVA_HOME option located at /var/opt/snapcenter/spl/etc/spl.properties is set to the correct JAVA version and the correct path. |
For the latest information about supported versions, see the NetApp Interoperability Matrix Tool
