SnapCenter software
Install SnapCenter Plug-in for Microsoft SQL Server
Contributors netapp-ivanad netapp-mdavidson
Provides a condensed set of install instructions for the SnapCenter Plug-in for Microsoft SQL Server.
Step 1: Set up Run As Credentials to install the Plug-in for Microsoft SQL Server
  1. In the left pane, click Settings > Credentials > New.
  2. Enter the credentials.
    For a built-in domain admin username format, use: NetBIOS\<username> or <username>@<domain> or <DomainFQDN>\<username>.
    For a built-in local admin username format, use <username>.
Step 2: Add a host and install the Plug-in for Microsoft SQL Server
  1. In the SnapCenter GUI left pane, click Hosts > Managed Hosts > Add.
  2. In the Hosts page of the wizard, perform the following:
    1. Host Type: Select Windows host type.
    2. Host name: Use the SQL host or specify the FQDN of a dedicated Windows host.
    3. Credentials: Select the valid credential name of the host that you created or create new credentials.
  3. In the Select Plug-ins to Install section, select Microsoft SQL Server.
  4. Click More Options to specify the following details:
    1. Port: Either retain the default port number or specify the port number.
    2. Installation Path: The default path is C:\Program Files\NetApp\SnapCenter. You can optionally customize the path.
    3. Add all hosts in the cluster: Select this check box if you are using SQL in WSFC.
    4. Skip preinstall checks: Select this check box if you already installed the plug-ins manually or you do not want to validate whether the host meets the requirements for installing the plug-in.
  5. Click Submit.
