Back up resources using PowerShell cmdlets
PDF of this doc site
Protect Microsoft SQL Server databases
Protect SAP HANA databases
Protect IBM Db2
Protect PostgreSQL
Creating your file...
You can use the PowerShell cmdlets to backup SQL Server databases or Windows file systems. This would include backing up a SQL Server database or Windows file system includes establishing a connection with the SnapCenter Server, discovering the SQL Server database instances or Windows file systems, adding a policy, creating a backup resource group, backing up, and verifying the backup.
You must have prepared the PowerShell environment to execute the PowerShell cmdlets.
You must have added the storage system connection and created a credential.
You must have added hosts and discovered resources.
Initiate a connection session with the SnapCenter Server for a specified user by using the Open-SmConnection cmdlet.
Open-smconnection -SMSbaseurl https://snapctr.demo.netapp.com:8146
The username and password prompt is displayed.
Create a backup policy by using the Add-SmPolicy cmdlet.
This example creates a new backup policy with a SQL backup type of FullBackup:
PS C:\> Add-SmPolicy -PolicyName TESTPolicy -PluginPolicyType SCSQL -PolicyType Backup -SqlBackupType FullBackup -Verbose
This example creates a new backup policy with a Windows file system backup type of CrashConsistent:
PS C:\> Add-SmPolicy -PolicyName FileSystemBackupPolicy -PluginPolicyType SCW -PolicyType Backup -ScwBackupType CrashConsistent -Verbose
Discover host resources by using the Get-SmResources cmdlet.
This example discovers the resources for the Microsoft SQL plug-in on the specified host:
C:\PS>PS C:\> Get-SmResources -HostName vise-f6.sddev.mycompany.com -PluginCode SCSQL
This example discovers the resources for Windows file systems on the specified host:
C:\PS>PS C:\> Get-SmResources -HostName vise2-f6.sddev.mycompany.com -PluginCode SCW
Add a new resource group to SnapCenter by using the Add-SmResourceGroup cmdlet.
This example creates a new SQL database backup resource group with the specified policy and resources:
PS C:\> Add-SmResourceGroup -ResourceGroupName AccountingResource -Resources @{"Host"="visef6.org.com"; "Type"="SQL Database";"Names"="vise-f6\PayrollDatabase"} -Policies "BackupPolicy"
This example creates a new Windows file system backup resource group with the specified policy and resources:
PS C:\> Add-SmResourceGroup -ResourceGroupName EngineeringResource -PluginCode SCW -Resources @{"Host"="WIN-VOK20IKID5I"; "Type"="Windows Filesystem";"Names"="E:\"} -Policies "EngineeringBackupPolicy"
Initiate a new backup job by using the New-SmBackup cmdlet.
PS C:> New-SmBackup -ResourceGroupName PayrollDataset -Policy FinancePolicy
View the status of the backup job by using the Get-SmBackupReport cmdlet.
This example displays a job summary report of all jobs that were run on the specified date:
PS C:\> Get-SmJobSummaryReport -Date '1/27/2016'
The information regarding the parameters that can be used with the cmdlet and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Cmdlet Reference Guide.
