Remove Exchange backups using PowerShell cmdlets
PDF of this doc site
Protect Microsoft SQL Server databases
Protect SAP HANA databases
Protect IBM Db2
Protect PostgreSQL
Creating your file...
Your file is ready
You can use the Remove-SmBackup cmdlet to delete Exchange backups if you no longer require them for other data protection operations.
You must have prepared the PowerShell environment to execute the PowerShell cmdlets.
The information regarding the parameters that can be used with the cmdlet and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Cmdlet Reference Guide.
Steps
Initiate a connection session with the SnapCenter Server for a specified user by using the Open-SmConnection cmdlet.
Open-SmConnection -SMSbaseurl https://snapctr.demo.netapp.com:8146/
Delete one or more backup using the
Remove-SmBackup
cmdlet.This example deletes two backups using their backup IDs:
Remove-SmBackup -BackupIds 3,4 Remove-SmBackup Are you sure want to remove the backup(s). [Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
