SnapCenter software
Add IBM Db2 resources manually to the SnapCenter plug-in host
Contributors netapp-yvonneo netapp-nsriram netapp-soumikd
Automatic discovery is not supported on Windows host. You must add Db2 instances and database resources manually.
Before you begin
  • You must have completed tasks such as installing the SnapCenter Server, adding hosts, and setting up storage system connections.
About this task
Manual discovery is not supported for the following configurations:
  • RDM and VMDK layouts
Steps
  1. In the left navigation pane, select Resources, and then select the SnapCenter Plug-in for IBM Db2 from the drop-down list.
  2. In the Resources page, select Add IBM DB2 Resource.
  3. In the Provide Resource Details page, perform the following actions:
    For this field…​ Do this…​
    Name
    Specify the database name.
    Host Name
    Enter the host name.
    Type
    Select database or instance.
    Instance
    Specify the name of the instance, which is the parent of the database.
    Mount paths
    Enter the mount paths where the resource is mounted. This is only applicable to Windows hosts.
    Credentials
    Select the credentials or add information for the credential.
    This field is optional.
  4. In the Provide Storage Footprint page, select a storage type and choose one or more volumes, LUNs, and qtrees, and then click Save.
    Optional: You can click the add policy form resource group icon to add more volumes, LUNs, and qtrees from other storage systems.
  5. Optional: In the Resource Settings page, for resources on Linux hosts where the SnapCenter Plug-in for IBM Db2 is installed, enter custom key-value pairs for the IBM Db2 plug-in. Custom key-value pairs are not supported for IBM Db2 databases that are registered as a centralized Windows plug-in.
  6. Review the summary, and then click Finish.
    The databases are displayed along with information such as the host name, associated resource groups and policies, and overall status.
If you want to provide users access to resources, you must assign the resources to the users. This enables users to perform the actions for which they have permissions on the assets that are assigned to them.
After adding the databases, you can modify the IBM Db2 database details.
