SnapCenter software
Create backup policies for Oracle databases in SnapCenter
Contributors netapp-soumikd
Before you use SnapCenter to back up Oracle database resources, you must create a backup policy for the resource or the resource group that you want to back up.
Steps
  1. In the left navigation pane, click Settings.
  2. In the Settings page, click Policies.
  3. Select Oracle Database from the drop-down list.
  4. Click New.
  5. In the Name page, enter the policy name and description.
  6. In the Policy type page, perform the following steps:
    1. Select Azure NetApp Files as the storage type.
    2. Select the backup type as either online or offline backup.
    3. If you want to catalog backup using Oracle Recovery Manager (RMAN), select Catalog backup with Oracle Recovery Manager (RMAN).
    4. If you want to prune archive logs after backup, select Prune archive logs after backup.
    5. Specify the delete archive log settings.
  7. In the Snapshot and backup page, perform the following steps:
    1. Select the frequency of the scheduled backup.
    2. Specify the retention settings.
    3. If you want to enable Azure NetApp Files backup, select Enable backup and specify the retention settings.
  8. In the Script page, enter the path and the arguments of the prescript or postscript that you want to run before or after the backup operation, respectively.
  9. In the Verification page, select the backup schedule for which you want to perform the verification operation and enter the path and the arguments of the prescript or postscript that you want to run before or after the verification operation, respectively.
  10. Review the summary and click Finish.
