Types of restore strategies supported for manually added NetApp supported plug-in resources
PDF of this doc site
Protect Microsoft SQL Server databases
Protect SAP HANA databases
Protect IBM Db2
Protect PostgreSQL
Creating your file...
Your file is ready
You must define a strategy before you can successfully perform restore operations using SnapCenter. There are two types of restore strategies for manually added NetApp supported plug-in resources.
You cannot recover manually added NetApp supported plug-in resources. |
Complete resource restore
Restores all volumes, qtrees, and LUNs of a resource
If the resource contains volumes or qtrees, the Snapshots taken after the Snapshot selected for restore on such volumes or qtrees are deleted and cannot be recovered. Also, if any other resource is hosted on the same volumes or qtrees, then that resource is also deleted. |
File level restore
Restores files from volumes, qtrees, or directories
Restores only the selected LUNs
