SnapCenter software
SnapCenter Plug-ins Package for Linux host requirements
Contributors netapp-yvonneo netapp-nsriram netapp-soumikd
Before you install the SnapCenter Plug-ins Package for Linux, you should be familiar with some basic host system space and sizing requirements.
Item Requirements
Operating systems
  • Red Hat Enterprise Linux
  • SUSE Linux Enterprise Server (SLES)
For the latest information about supported versions, see the NetApp Interoperability Matrix Tool.
Minimum RAM for the SnapCenter plug-in on host
1 GB
Minimum install and log space for the SnapCenter plug-in on host
2 GB
Note You should allocate sufficient disk space and monitor the storage consumption by the logs folder. The log space required varies, depending on the number of the entities to be protected and the frequency of data protection operations. If there is no sufficient disk space, the logs will not be created for the recently run operations.
Required software packages
  • Java 17 (Oracle Java, OpenJDK, or SAP JDK) for SnapCenter 6.2.1 and later or Java 11 for SnapCenter 6.2 and earlier
    Note Non-root users must have execute permissions to run Java.
If you have upgraded Java to the latest version, you must ensure that the JAVA_HOME option located at /var/opt/snapcenter/spl/etc/spl.properties is set to the correct Java version and the correct path.
