SnapCenter software
Enable CA certificates for SnapCenter plug-ins
Contributors netapp-nsriram netapp-soumikd
You should configure the CA certificates and deploy the CA certificates in the SnapCenter Server and the corresponding plug-in hosts. You should enable the CA certificate validation for the plug-ins.
Before you begin
  • You can enable or disable the CA certificates using the run Set-SmCertificateSettings cmdlet.
  • You can display the certificate status for the plug-ins using the Get-SmCertificateSettings.
The information regarding the parameters that can be used with the cmdlet and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Cmdlet Reference Guide.
Steps
  1. In the left navigation pane, click Hosts.
  2. In the Hosts page, click Managed Hosts.
  3. Select single or multiple plug-in hosts.
  4. Click More options.
  5. Select Enable Certificate Validation.
After you finish
The Managed Hosts tab host displays a padlock and the color of the padlock indicates the status of the connection between SnapCenter Server and the plug-in host.
  • CA certificate is neither enabled nor assigned to the plug-in host icon indicates that the CA certificate is neither enabled nor assigned to the plug-in host.
  • CA certificate is successfully validated icon indicates that the CA certificate is successfully validated.
  • CA certificate could not be validated icon indicates that the CA certificate could not be validated.
  • the connection information could not be retrieved icon indicates that the connection information could not be retrieved.
    Note When the status is yellow or green, the data protection operations completes successfully.
