Install SnapCenter Plug-in for VMware vSphere
If your database or filesystem is stored on virtual machines (VMs), or if you want to protect VMs and datastores, you must deploy the SnapCenter Plug-in for VMware vSphere virtual appliance.
For information to deploy, see Deployment Overview.
Deploy CA certificate
To configure the CA Certificate with SnapCenter Plug-in for VMware vSphere, see Create or import SSL certificate.
Configure the CRL file
SnapCenter Plug-in for VMware vSphere looks for the CRL files in a pre-configured directory. Default directory of the CRL files for SnapCenter Plug-in for VMware vSphere is /opt/netapp/config/crl.
You can place more than one CRL file in this directory. The incoming certificates will be verified against each CRL.
