SnapCenter software
SnapCenter Plug-in for PostgreSQL features
Contributors netapp-nsriram
SnapCenter integrates with the plug-in application and with NetApp technologies on the storage system. To work with the Plug-in for PostgreSQL Cluster, you use the SnapCenter graphical user interface.
  • Unified graphical user interface
    The SnapCenter interface provides standardization and consistency across plug-ins and environments. The SnapCenter interface enables you to complete consistent backup, restore, and clone operations across plug-ins, use centralized reporting, use at-a-glance dashboard views, set up role-based access control (RBAC), and monitor jobs across all plug-ins.
  • Automated central administration
    You can schedule backup operations, configure policy-based backup retention, and perform restore operations. You can also proactively monitor your environment by configuring SnapCenter to send email alerts.
  • Nondisruptive NetApp snapshot copy technology
    SnapCenter uses NetApp snapshot technology with the Plug-in for PostgreSQL cluster to back up resources.
Using the Plug-in for PostgreSQL also offers the following benefits:
  • Support for backup, restore, and clone workflows
  • RBAC-supported security and centralized role delegation
    You can also set the credentials so that the authorized SnapCenter users have application-level permissions.
  • Creation of space-efficient and point-in-time copies of resources for testing or data extraction by using NetApp FlexClone technology
    A FlexClone license is required on the storage system where you want to create the clone.
  • Support for the consistency group (CG) snapshot feature of ONTAP as part of creating backups.
  • Capability to run multiple backups simultaneously across multiple resource hosts
    In a single operation, snapshots are consolidated when resources in a single host share the same volume.
  • Capability to create snapshots using external commands.
  • Support for Linux LVM on XFS file system.
