Create backup policies for SQL Server databases in SnapCenter
You can create a backup policy for the resource or the resource group before you use SnapCenter to back up SQL Server resources, or you can create a backup policy at the time you create a resource group or backup a single resource.
You must have defined your data protection strategy.
You must have prepared for data protection by completing tasks such as installing SnapCenter, adding hosts, identifying resources, and creating storage system connections.
You must have configured the host log directory for log backup.
You must have refreshed (discovered) the SQL Server resources.
If you are replicating Snapshots to a mirror or vault, the SnapCenter administrator must have assigned the storage virtual machines (SVMs) for both the source volumes and destination volumes to you.
For information about how administrators assign resources to users, see the SnapCenter installation information.
If you want to run the PowerShell scripts in prescripts and postscripts, you should set the value of the usePowershellProcessforScripts parameter to true in the web.config file.
The default value is false.
Review the SnapMirror active sync specific prerequisites and limitations. For information, refer Object limits for SnapMirror active sync.
A backup policy is a set of rules that governs how you manage and retain backups, and how frequently the resource or resource group is backed up. Additionally, you can specify replication and script settings. Specifying options in a policy saves time when you want to reuse the policy for another resource group.
The SCRIPTS_PATH is defined using the PredefinedWindowsScriptsDirectory key located in the SMCoreServiceHost.exe.Config file of the plug-in host.
If needed, you can change this path and restart SMcore service. It is recommended that you use the default path for security.
The value of the key can be displayed from swagger through the API: API /4.7/configsettings
You can use the GET API to display the value of the key. SET API is not supported.
SnapLock
If 'Retain the backup copies for a specific number of days' option is selected, then the SnapLock retention period must be lesser than or equal to the mentioned retention days.
Specifying a Snapshot locking period prevents deletion of the Snapshots until the retention period expires. This could lead to retaining a larger number of Snapshots than the count specified in the policy.
For ONTAP 9.12.1 and below version, the clones created from the SnapLock Vault Snapshots as part of restore will inherit the SnapLock Vault expiry time. Storage admin should manually cleanup the clones post the SnapLock expiry time.
Step 1: Create Policy Name
In the left navigation pane, select Settings.
In the Settings page, select Policies.
Select New.
In the Name page, enter the policy name and details.
Step 2: Configure policy options
In the Policy type page, perform the following steps:
Select your storage type.
Select your policy scope.
Full Backup and Log BackupBack up the database files and transaction logs and to truncate the transaction logs.
Select Full backup and Log backup.
Enter the maximum number of databases that should be backed up for each Snapshot.
You must increase this value if you want to run multiple backup operations concurrently.
Full BackupBack up the database files.
Select Full backup.
Enter the maximum number of databases that should be backed up for each Snapshot. Default value is 100
Log Backup-
Back up the transaction logs.
Select Log backup.
Copy Only Backup-
If you are backing up your resources by using another backup application, select Copy only backup.
Keeping the transaction logs intact allows any backup application to restore the databases. You typically should not use the copy only option in any other circumstance.
Microsoft SQL does not support the Copy only backup option together with the Full backup and Log backup option for secondary storage. -
Step 3: Configure Availability Group settings
In the Availability Group Settings section, perform the following actions:
Backup on preferred backup replica only.
Select this option to backup only on preferred backup replica. The preferred backup replica is decided by the backup preferences configured for the AG in the SQL Server.
Select replicas for backup.
Choose the primary AG replica or the secondary AG replica for the backup.
Select Backup priority (Minimum and Maximum backup priority)
Specify a minimum backup priority number, and a maximum backup priority number that decide the AG replica for backup. For example, you can have a minimum priority of 10 and a maximum priority of 50. In this case, all the AG replicas with a priority more than 10 and less than 50 are considered for backup.
By default, the minimum priority is 1 and maximum priority is 100.
In cluster configurations, the backups are retained at each node of the cluster according to the retention settings set in the policy. If the owner node of the AG changes, the backups are taken according to the retention settings and the backups of the previous owner node will be retained. The retention for AG is applicable only at the node level. -
Step 4: Configure Snapshot and Replication settings
In the Snapshot and Replication page, perform the following steps:
Specify the schedule type by selecting On demand, Hourly, Daily, Weekly, or Monthly.
You can only select one schedule type for a policy.
You can specify the schedule (start date, end date, and frequency) for backup operation while creating a resource group. This enables you to create resource groups that share the same policy and backup frequency, but lets you assign different backup schedules to each policy. If you have scheduled for 2:00 a.m., the schedule will not be triggered during daylight saving time (DST).
Step 5: Configure up-to-the minute retention settings
In the Up-to-the minute retention settings section, depending on the backup type selected in the backup type page, perform one or more of the following actions:
Retain only a specific number of Snapshots.
Select the Keep log backups applicable to last <number> days option, and specify the number of days to be retained. If you near this limit, you might want to delete older copies.
Retain the backup copies for a specific number of days.
Select the Keep log backups applicable to last <number> days of full backups option, and specify the number of days to keep the log backup copies.
Step 6: Configure Snapshot settings
For the Full backup retention settings, perform the following actions:
Specify total number of snapshots to keep
To specify the number of snapshots to keep, select Copies to keep.
If the number of snapshots exceeds the specified number, the snapshots are deleted with the oldest copies deleted first.
By default, the value of retention count is set to 2. If you set the retention count to 1, the retention operation might fail because the first snapshot is the reference snapshot for the SnapVault relationship until a newer snapshot is replicated to the target. The maximum retention value is 1018. Backups will fail if retention is set to a value higher than what the underlying NetApp ONTAP version supports.
Length of time to keep snapshots
If you want to specify the number of days for which you want to keep the snapshots before deleting them, select Retain copies for.
Select Snapshot copy locking period and specify the duration in days, months, or years.
Snaplock retention period should be less than 100 years.
Select a Policy label.
You can assign SnapMirror labels to primary snapshots for remote replication, allowing the primary snapshots to offload the snapshot replication operation from SnapCenter to ONTAP secondary systems. This can be done without enabling SnapMirror or SnapVault option in the policy page.
Step 7: Configure secondary replication options
In the Select secondary replication options section, select one or both of the following secondary replication options:
Update SnapMirror after creating a local Snapshot copy.
Select this option to create mirror copies of backup sets on another volume (SnapMirror).
This option should be enabled for SnapMirror active sync.
During secondary replication, the SnapLock expiry time loads the primary SnapLock expiry time. Clicking the Refresh button in the Topology page refreshes the secondary and primary SnapLock expiry time that are retrieved from ONTAP.
Update SnapVault after creating a Snapshot copy.
Select this option to perform disk-to-disk backup replication.
When SnapLock is configured only on the secondary from ONTAP known as SnapLock Vault, clicking the Refresh button in the Topology page refreshes the locking period on the secondary that is retrieved from ONTAP.
For more information on SnapLock Vault see Commit Snapshot copies to WORM on a vault destination
Enter the number of replication attempts that should occur before the process halts.
Step 8: Configure script settings
In the Script page, enter the path and the arguments of the prescript or postscript that should be run before or after the backup operation, respectively.
For example, you can run a script to update SNMP traps, automate alerts, and send logs.
The prescripts or postscripts path should not include drives or shares. The path should be relative to the SCRIPTS_PATH. You must configure the SnapMirror retention policy in ONTAP so that the secondary storage does not reach the maximum limit of Snapshots.
Step 9: Configure verification settings
In the Verification page, perform the following steps:
In the Run verification for following backup schedules section, select the schedule frequency.
In the Database consistency check options section, perform the following actions:
Limit the integrity structure to physical structure of the database (PHYSICAL_ONLY)
Select Limit the integrity structure to physical structure of the database (PHYSICAL_ONLY) to limit the integrity check to the physical structure of the database and to detect torn pages, checksum failures, and common hardware failures that impact the database.
Suppress all information messages (NO INFOMSGS)
Select Supress all information messages (NO_INFOMSGS) to suppress all informational messages. Selected by default.
Display all reported error messages per object (ALL_ERRORMSGS)
Select Display all reported error messages per object (ALL_ERRORMSGS) to display all the reported errors per object.
Do not check nonclustered indexes (NOINDEX)
Select Do not check nonclustered indexes (NOINDEX) if you do not want to check nonclustered indexes. The SQL Server database uses Microsoft SQL Server Database Consistency Checker (DBCC) to check the logical and physical integrity of the objects in the database.
Limit the checks and obtain the locks instead of using an internal database Snapshot (TABLOCK)
Select Limit the checks and obtain the locks instead of using an internal database Snapshot copy (TABLOCK) to limit the checks and obtain locks instead of using an internal database Snapshot.
In the Log Backup section, select Verify log backup upon completion to verify the log backup upon completion.
In the Verification script settings section, enter the path and the arguments of the prescript or postscript that should be run before or after the verification operation, respectively.
Step 10: Review summary
Review the summary, and then select Finish.
