The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Storage types supported by SnapCenter Plug-in for PostgreSQL
Your file is ready
SnapCenter supports a wide range of storage types on both physical machines and virtual machines (VMs). You must verify the support for your storage type before installing SnapCenter Plug-in for PostgreSQL.
Machine
Storage type
Physical server
FC-connected LUNs
iSCSI-connected LUNs
NFS-connected volumes
VMware ESXi
RDM LUNs connected by an FC or iSCSI ESXi HBAScanning of host bus adapters (HBAs) might take long time to complete because SnapCenter scans all the host bus adaptors present in the host.
You can edit the LinuxConfig.pm file located at /opt/NetApp/snapcenter/spl/plugins/scu/scucore/modules/SCU/Config to set the value of the SCSI_HOSTS_OPTIMIZED_RESCAN parameter to 1 to rescan only those HBAs that are listed in HBA_DRIVER_NAMES.
iSCSI LUNs connected directly to the guest system by the iSCSI initiator
VMDKs on NFS datastores
VMDKs on VMFS
NFS volumes connected directly to the guest system
vVol datastores on both NFS and SAN
vVol datastore can only be provisioned with ONTAP Tools for VMware vSphere.
