Configure a CA certificate with the SnapCenter Plug-in Loader service on a Linux host
You should manage the password of SPL keystore and its certificate, configure the CA certificate, configure root or intermediate certificates to SPL trust-store, and configure CA signed key pair to SPL trust-store with SnapCenter Plug-in Loader service to activate the installed digital certificate.
SPL uses the file 'keystore.jks', which is located at ‘/var/opt/snapcenter/spl/etc’ both as its trust-store and key-store. |
Manage password for SPL keystore and alias of the CA signed key pair in use
Steps
You can retrieve SPL keystore default password from SPL property file.
It is the value corresponding to the key 'SPL_KEYSTORE_PASS'.
Change the keystore password:
keytool -storepasswd -keystore keystore.jks
Change the password for all aliases of private key entries in the keystore to the same password used for the keystore:
keytool -keypasswd -alias "<alias_name>" -keystore keystore.jks
Update the same for the key SPL_KEYSTORE_PASS in spl.properties file.
Restart the service after changing the password.
Password for SPL keystore and for all the associated alias password of the private key should be same. |
Configure root or intermediate certificates to SPL trust-store
You should configure the root or intermediate certificates without the private key to SPL trust-store.
Steps
Navigate to the folder containing the SPL keystore: /var/opt/snapcenter/spl/etc.
Locate the file 'keystore.jks'.
List the added certificates in the keystore:
keytool -list -v -keystore keystore.jks
Add a root or intermediate certificate:
keytool -import -trustcacerts -alias <AliasNameForCerticateToBeImported> -file /<CertificatePath> -keystore keystore.jks
Restart the service after configuring the root or intermediate certificates to SPL trust-store.
You should add the root CA certificate and then the intermediate CA certificates. |
Configure CA signed key pair to SPL trust-store
You should configure the CA signed key pair to the SPL trust-store.
Steps
Navigate to the folder containing the SPL's keystore /var/opt/snapcenter/spl/etc.
Add the CA certificate having both private and public key.
keytool -importkeystore -srckeystore <CertificatePathToImport> -srcstoretype pkcs12 -destkeystore keystore.jks -deststoretype JKS
List the added certificates in the keystore.
Verify that the keystore contains the alias corresponding to the new CA certificate, which was added to the keystore.
Change the added private key password for CA certificate to the keystore password.
Default SPL keystore password is the value of the key SPL_KEYSTORE_PASS in spl.properties file.
keytool -keypasswd -alias "<aliasNameOfAddedCertInKeystore>" -keystore keystore.jks
If the alias name in the CA certificate is long and contains space or special characters ("*",","), change the alias name to a simple name:
keytool -changealias -alias "<OrignalAliasName>" -destalias "<NewAliasName>" -keystore keystore.jks
Configure the alias name from the keystore located in spl.properties file.
Update this value against the key SPL_CERTIFICATE_ALIAS.
Restart the service after configuring the CA signed key pair to SPL trust-store.
Configure certificate revocation list (CRL) for SPL
You should configure the CRL for SPL
About this task
SPL will look for the CRL files in a pre-configured directory.
Default directory for the CRL files for SPL is /var/opt/snapcenter/spl/etc/crl.
Steps
You can modify and update the default directory in spl.properties file against the key SPL_CRL_PATH.
You can place more than one CRL file in this directory.
The incoming certificates will be verified against each CRL.
