SnapCenter software
SnapCenter prescript and postscript environment variables for clone
Contributors netapp-soumikd
SnapCenter allows you to use the predefined environment variables when you execute the prescript and postscript while cloning a database.
Supported predefined environment variables for cloning a database
  • SC_ORIGINAL_SID specifies the SID of the source database.
    This parameter will be populated for application volumes.
    Example: NFSB32
  • SC_ORIGINAL_HOST specifies the name of the source host.
    Example: asmrac1.gdl.englab.netapp.com
  • SC_ORACLE_HOME specifies the path of the target database's Oracle home directory.
    Example: /ora01/app/oracle/product/18.1.0/db_1
  • SC_BACKUP_NAME" specifies the name of the backup.
    Examples:
    • If the database is not running in ARCHIVELOG mode: DATA@RG2_scspr2417819002_07-20-2021_12.16.48.9267_0|LOG@RG2_scspr2417819002_07-20-2021_12.16.48.9267_1
    • If the database is running in ARCHIVELOG mode: DATA@RG2_scspr2417819002_07-20-2021_12.16.48.9267_0|LOG:RG2_scspr2417819002_07-20-2021_12.16.48.9267_1,RG2_scspr2417819002_07-21-2021_12.16.48.9267_1,RG2_scspr2417819002_07-22-2021_12.16.48.9267_1
  • SC_AV_NAME specifies the names of the application volumes.
    Example: AV1|AV2
  • SC_ORIGINAL_OS_USER specifies the operating system owner of the source database.
    Example: oracle
  • SC_ORIGINAL_OS_GROUP specifies the operating system group of the source database.
    Example: oinstall
  • SC_TARGET_SID" specifies the SID of the cloned database.
    For PDB clone workflow, the value of this parameter will not be predefined.
    Example: clonedb
  • SC_TARGET_HOST specifies the name of the host where the database will be cloned.
  • SC_TARGET_OS_USER specifies the operating system owner of the cloned database.
    Example: oracle
  • SC_TARGET_OS_GROUP specifies the operating system group of the cloned database.
    Example: oinstall
  • SC_TARGET_DB_PORT specifies the database port of the cloned database.
    Example: 1521
For information about delimiters, see Supported delimiters.
