SnapCenter Software
SnapCenter Custom Plug-ins overview
Contributors netapp-nsriram
You can develop custom plug-ins for applications that you use and then use SnapCenter to backup, restore, or clone these applications. Your custom plug-ins act as host-side components of the NetApp SnapCenter Software, enabling application-aware data protection and management of resources.
When custom plug-ins are installed, you can use SnapCenter with NetApp SnapMirror technology to create mirror copies of backup sets on another volume and use NetApp SnapVault technology to perform disk-to-disk backup replication. The custom plug-ins can be used in both Windows and Linux environments.
Note SnapCenterCLI does not support custom plug-ins commands.
You can install the custom plug-in from the Add Host page.
Note SnapCenter support policy will cover support for SnapCenter custom plug-in framework, core engine, and the associated APIs. Support will not cover the plug-in source code and the associated scripts built on the custom plug-in framework.
You can create your own custom plug-ins by referring to Develop a plug-in for your application guide.
