Add MySQL resources manually to the plug-in host
Automatic discovery is not supported on Windows host. You must add MySQL instances and database resources manually.
You must have completed tasks such as installing the SnapCenter Server, adding hosts, and setting up storage system connections.
In the left navigation pane, select the SnapCenter Plug-in for MySQL from the drop-down list, and then click Resources.
In the Resources page, click Add MySQL resources.
In the Provide Resource Details page, perform the following actions:
For this field… Do this… Name
Specify the database name.
Host Name
Enter the host name.
Type
Select instance.
Instance
Not applicable.
Credentials
Select the credentials or add information for the credential.
This is optional.
In the Provide Storage Footprint page, select a storage type and choose one or more volumes, LUNs, and qtrees, and then click Save.
Optional: You can click the
icon to add more volumes, LUNs, and qtrees from other storage systems. -
Optional: In the Resource Settings page, enter custom key-value pairs for MySQL plug-in.
Review the summary, and then click Finish.
The databases are displayed along with information such as the host name, associated resource groups and policies, and overall status
If you want to provide users access to resources, you must assign the resources to the users. This enables users to perform the actions for which they have permissions on the assets that are assigned to them.
After adding the databases, you can modify the MySQL database details.
