SnapCenter software
Storage types supported by NetApp supported plug-ins
Contributors netapp-nsriram
SnapCenter supports a wide range of storage types on both physical and virtual machines. You must verify the support for your storage type before installing NetApp supported plug-ins.
Machine Storage type
Physical and NFS direct mounts on the VM hosts (VMDKs and RDM LUNs are not supported.)
FC-connected LUNs
iSCSI-connected LUNs
NFS-connected volumes
VMware ESXi
vVol datastores on both NFS and SAN
vVol datastore can only be provisioned with ONTAP Tools for VMware vSphere.
