Prerequisites to use the SnapCenter Plug-in for PostgreSQL
Before you use SnapCenter Plug-in for PostgreSQL, the SnapCenter administrator must install and configure the SnapCenter Server and perform the prerequisite tasks.
Install and configure SnapCenter Server.
Log in to SnapCenter Server.
Configure the SnapCenter environment by adding storage system connections and creating credentials, if applicable.
Install Java 17 (for SnapCenter 6.2.1 and later) or Java 11 (for SnapCenter 6.2 and earlier) on your Linux or Windows host.
Non-root users must have execute permissions to run Java. You must set the Java path in the environmental path variable of the host machine.
Set up SnapMirror and SnapVault, if you want backup replication.
