Prerequisites for using the SnapCenter Plug-in for MySQL
Before you use SnapCenter Plug-in for MySQL, the SnapCenter administrator must install and configure the SnapCenter Server and perform the prerequisite tasks.
Install and configure SnapCenter Server.
Log in to SnapCenter Server.
Configure the SnapCenter environment by adding storage system connections and creating credentials, if applicable.
Install Java 11 on your Linux or Windows host.
You must set the Java path in the environmental path variable of the host machine.
Set up SnapMirror and SnapVault, if you want backup replication.
