SnapCenter software
Prerequisites for using the SnapCenter Plug-in for MySQL
Before you use SnapCenter Plug-in for MySQL, the SnapCenter administrator must install and configure the SnapCenter Server and perform the prerequisite tasks.
  • Install and configure SnapCenter Server.
  • Log in to SnapCenter Server.
  • Configure the SnapCenter environment by adding storage system connections and creating credentials, if applicable.
  • Install Java 11 on your Linux or Windows host.
    You must set the Java path in the environmental path variable of the host machine.
  • Set up SnapMirror and SnapVault, if you want backup replication.
