Host requirements for installing the SnapCenter Plug-ins Package for Linux
PDF of this doc site
Protect Microsoft SQL Server databases
Protect SAP HANA databases
Creating your file...
Your file is ready
You should ensure that the host meets the requirements before installing the SnapCenter Plug-ins Package for Linux.
Item | Requirements | ||
Operating systems |
Minimum RAM for the SnapCenter plug-in on host |
1 GB |
Minimum install and log space for the SnapCenter plug-in on host |
2 GB
Required software packages |
Java 1.8 (64-bit) Oracle Java or OpenJDK If you have upgraded JAVA to the latest version, you must ensure that the JAVA_HOME option located at /var/opt/snapcenter/spl/etc/spl.properties is set to the correct JAVA version and the correct path. |
For the latest information about supported versions, see the NetApp Interoperability Matrix Tool
