SnapCenter Software 4.8
Host requirements for installing the SnapCenter Plug-ins Package for Linux
Contributors netapp-soumikd
You should ensure that the host meets the requirements before installing the SnapCenter Plug-ins Package for Linux.
Item Requirements
Operating systems
  • Red Hat Enterprise Linux
  • Oracle Linux
  • SUSE Linux Enterprise Server (SLES)
Minimum RAM for the SnapCenter plug-in on host
1 GB
Minimum install and log space for the SnapCenter plug-in on host
2 GB
Note You should allocate sufficient disk space and monitor the storage consumption by the logs folder. The log space required varies depending on the number of the entities to be protected and the frequency of data protection operations. If there is no sufficient disk space, the logs will not be created for the recently run operations.
Required software packages
Java 1.8 (64-bit)Oracle Java or OpenJDK flavors
If you have upgraded JAVA to the latest version, you must ensure that the JAVA_HOME option located at /var/opt/snapcenter/spl/etc/spl.properties is set to the correct JAVA version and the correct path.
For the latest information about supported versions, see the NetApp Interoperability Matrix Tool
