Minimum ONTAP privileges required for custom plug-in
The minimum ONTAP privileges that are required vary according to the SnapCenter plug-ins you are using for data protection.
| All-access commands: Minimum privileges required for ONTAP 8.3.0 and later |
event generate-autosupport-log  |
job history show job stop  |
lun attribute show lun create lun delete lun geometry lun igroup add lun igroup create lun igroup delete lun igroup rename lun igroup show lun mapping add-reporting-nodes lun mapping create lun mapping delete lun mapping remove-reporting-nodes lun mapping show lun modify lun move-in-volume lun offline lun online lun resize lun serial lun show  |
network interface  |
snapmirror policy add-rule snapmirror policy modify-rule snapmirror policy remove-rule snapmirror policy show snapmirror restore snapmirror show snapmirror show-history snapmirror update snapmirror update-ls-set snapmirror list-destinations  |
version  |
volume clone create volume clone show volume clone split start volume clone split stop volume create volume destroy volume file clone create volume file show-disk-usage volume offline volume online volume modify volume qtree create volume qtree delete volume qtree modify volume qtree show volume restrict volume show volume snapshot create volume snapshot delete volume snapshot modify volume snapshot rename volume snapshot restore volume snapshot restore-file volume snapshot show volume unmount  |
vserver cifs vserver cifs share create vserver cifs share delete vserver cifs shadowcopy show vserver cifs share show vserver cifs show vserver export-policy create vserver export-policy delete vserver export-policy rule create vserver export-policy rule show vserver export-policy show vserver iscsi connection show vserver show  |
| Read-only commands: Minimum privileges required for ONTAP 8.3.0 and later |
network interface  |
