SnapCenter Software 4.8
Minimum ONTAP privileges required for Plug-in for Oracle
Contributors netapp-soumikd
The minimum ONTAP privileges that are required vary according to the SnapCenter plug-ins you are using for data protection.
All-access commands: Minimum privileges required for ONTAP 8.3.0 and later
  • event generate-autosupport-log
  • job history show
  • job stop
  • lun
  • lun attribute show
  • lun create
  • lun delete
  • lun geometry
  • lun igroup add
  • lun igroup create
  • lun igroup delete
  • lun igroup rename
  • lun igroup show
  • lun mapping add-reporting-nodes
  • lun mapping create
  • lun mapping delete
  • lun mapping remove-reporting-nodes
  • lun mapping show
  • lun modify
  • lun move-in-volume
  • lun offline
  • lun online
  • lun persistent-reservation clear
  • lun resize
  • lun serial
  • lun show
  • snapmirror policy add-rule
  • snapmirror policy modify-rule
  • snapmirror policy remove-rule
  • snapmirror policy show
  • snapmirror restore
  • snapmirror show
  • snapmirror show-history
  • snapmirror update
  • snapmirror update-ls-set
  • snapmirror list-destinations
  • version
  • volume clone create
  • volume clone show
  • volume clone split start
  • volume clone split stop
  • volume create
  • volume destroy
  • volume file clone create
  • volume file show-disk-usage
  • volume offline
  • volume online
  • volume modify
  • volume qtree create
  • volume qtree delete
  • volume qtree modify
  • volume qtree show
  • volume restrict
  • volume show
  • volume snapshot create
  • volume snapshot delete
  • volume snapshot modify
  • volume snapshot rename
  • volume snapshot restore
  • volume snapshot restore-file
  • volume snapshot show
  • volume unmount
  • vserver
  • vserver cifs
  • vserver cifs shadowcopy show
  • vserver show
  • network interface
  • network interface show
  • metrocluster show
