Minimum ONTAP privileges required for Plug-in for Oracle
The minimum ONTAP privileges that are required vary according to the SnapCenter plug-ins you are using for data protection.
All-access commands: Minimum privileges required for ONTAP 8.3.0 and later |
job history show
job stop
lun
lun attribute show
lun create
lun delete
lun geometry
lun igroup add
lun igroup create
lun igroup delete
lun igroup rename
lun igroup show
lun mapping add-reporting-nodes
lun mapping create
lun mapping delete
lun mapping remove-reporting-nodes
lun mapping show
lun modify
lun move-in-volume
lun offline
lun online
lun persistent-reservation clear
lun resize
lun serial
lun show
snapmirror policy add-rule
snapmirror policy modify-rule
snapmirror policy remove-rule
snapmirror policy show
snapmirror restore
snapmirror show
snapmirror show-history
snapmirror update
snapmirror update-ls-set
snapmirror list-destinations
network interface
network interface show
