SnapCenter Software 4.9
Minimum ONTAP privileges required for Plug-in for Oracle
Contributors netapp-soumikd
The minimum ONTAP privileges that are required vary according to the SnapCenter plug-ins you are using for data protection.
  • All-access commands: Minimum privileges required for ONTAP 8.3.0 and later
    • event generate-autosupport-log
    • job history show
    • job stop
    • lun
    • lun attribute show
    • lun create
    • lun delete
    • lun geometry
    • lun igroup add
    • lun igroup create
    • lun igroup delete
    • lun igroup rename
    • lun igroup show
    • lun mapping add-reporting-nodes
    • lun mapping create
    • lun mapping delete
    • lun mapping remove-reporting-nodes
    • lun mapping show
    • lun modify
    • lun move-in-volume
    • lun offline
    • lun online
    • lun persistent-reservation clear
    • lun resize
    • lun serial
    • lun show
    • snapmirror policy add-rule
    • snapmirror policy modify-rule
    • snapmirror policy remove-rule
    • snapmirror policy show
    • snapmirror restore
    • snapmirror show
    • snapmirror show-history
    • snapmirror update
    • snapmirror update-ls-set
    • snapmirror list-destinations
    • version
    • volume clone create
    • volume clone show
    • volume clone split start
    • volume clone split stop
    • volume create
    • volume destroy
    • volume file clone create
    • volume file show-disk-usage
    • volume offline
    • volume online
    • volume modify
    • volume qtree create
    • volume qtree delete
    • volume qtree modify
    • volume qtree show
    • volume restrict
    • volume show
    • volume snapshot create
    • volume snapshot delete
    • volume snapshot modify
    • volume snapshot rename
    • volume snapshot restore
    • volume snapshot restore-file
    • volume snapshot show
    • volume unmount
    • vserver
    • vserver cifs
    • vserver cifs shadowcopy show
    • vserver show
    • network interface
    • network interface show
    • metrocluster show
