Create resource groups and attach policies for Exchange Servers
A resource group is required for any data protection job. You must also attach one or more policies to the resource group to define the type of data protection job that you want to perform and the protection schedule.
About this task
The SCRIPTS_PATH is defined using the PredefinedWindowsScriptsDirectory key located in the SMCoreServiceHost.exe.Config file of the plug-in host.
If needed, you can change this path and restart SMcore service. It is recommended that you use the default path for security.
The value of the key can be displayed from swagger through the API: API /4.7/configsettings
You can use the GET API to display the value of the key. SET API is not supported.
Steps
In the left navigation pane, click Resources, and then select the Microsoft Exchange Server plug-in from the list.
In the Resources page, select Database from the View list.
If you have recently added a resource to SnapCenter, click Refresh Resources to view the newly added resource. -
Click New Resource Group.
In the Name page, perform the following actions:
For this field… Do this… Name
Enter the resource group name.
The resource group name should not exceed 250 characters. Tags
Enter one or more labels that will help you later search for the resource group.
For example, if you add HR as a tag to multiple resource groups, you can later find all resource groups associated with the HR tag.
Use custom name format for Snapshot copy
Optional: Enter a custom Snapshot copy name and format.
For example, customtext_resourcegroup_policy_hostname or resourcegroup_hostname. By default, a timestamp is appended to the Snapshot copy name.
In the Resources page, perform the following steps:
Select the resource type and the Database Availability Group from drop-down lists to filter the list of available resources.
If you have recently added resources, they will appear in the list of Available Resources only after you refresh your resource list.
In the Available Resources and Selected Resources sections, the database name is displayed with the FQDN of the host. This FQDN only indicates that the database is active on that specific host and might not take backup on this host. You should select one or more backup servers from the Server selection option, where you want to take backup in case you have selected the Back up copies on servers to be selected at backup job creation time option in the policy.
Type the name of the resource in the search text box, or scroll to locate a resource.
To move resources from the Available Resources section to the Selected Resources section, perform one of the following steps:
Select Autoselect all resources on same storage volume to move all of the resources on the same volume to the Selected Resources section.
Select the resources from the Available Resources section and then click the right arrow to move them to the Selected Resources section.
Resource groups of SnapCenter for Microsoft Exchange Server cannot have more than 30 databases per Snapshot copy. If there are more than 30 databases in one resource group, a second Snapshot copy is created for the additional databases. Therefore, 2 sub jobs are created under the main backup job. For backups having secondary replication, while SnapMirror or SnapVault update is in progress, there could be scenarios where the update for both the sub-jobs overlap. The main backup job keeps on running forever even if the logs indicate that the job is completed.
In the Policies page, perform the following steps:
Select one or more policies from the drop-down list.
You can also create a policy by clicking .
If a policy contains the Back up copies on servers to be selected at backup job creation time option, a server selection option is displayed to select one or more servers. The server selection option will list only the server where the selected database is on NetApp storage. In the Configure schedules for selected policies section, the selected policies are listed.
In the Configure schedules for selected policies section, click
in the Configure Schedules column for the policy for which you want to configure the schedule.
In the Add schedules for policy policy_name dialog box, configure the schedule by specifying the start date, expiration date, and frequency, and then click OK.
You must do this for each frequency listed in the policy. The configured schedules are listed in the Applied Schedules column in the Configure schedules for selected policies section.
Third party backup schedules are not supported when they overlap with SnapCenter backup schedules.
In the Notification page, from the Email preference drop-down list, select the scenarios in which you want to send the emails.
You must also specify the sender and receiver email addresses, and the subject of the email. If you want to attach the report of the operation performed on the resource group, select Attach Job Report.
For email notification, you must have specified the SMTP server details either using the GUI or PowerShell command
Set-SmSmtpServer
.The information regarding the parameters that can be used with the cmdlet and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Cmdlet Reference Guide.
Review the summary, and then click Finish.
