SnapCenter Plug-in for VMware vSphere 6.2
Upgrade from an earlier release of the SCV
Contributors netapp-jani jani ronya netapp-yvonneo
Note Upgrade to SCV 6.2 is supported only on VMware vCenter Server 7 update 1 and later versions, for VMware vCenter Server prior to version 7 update 1, you should continue to use SCV 4.7. The upgrade is disruptive on unsupported versions of VMware vCenter Server.
If you are using the SnapCenter Plug-in for VMware vSphere virtual appliance, you can upgrade to a newer release.
The upgrade process unregisters the existing plug-in and deploys a plug-in that is compatible only with vSphere 7.0U1 and later versions.
Caution Before upgrading, verify that your environment meets the system requirements. Refer to SnapCenter Plug-in for VMware vSphere Deployment Planning and Requirements for details.
Upgrade paths
If you are on SnapCenter Plug-in for VMware vSphere (SCV) version…​
You can directly upgrade SnapCenter Plug-in for VMware vSphere to…​
SCV 6.1
Upgrade to SCV 6.2
SCV 6.0
Upgrade to SCV 6.1 and SCV 6.2
SCV 5.0
Upgrade to SCV 6.0 and SCV 6.1
SCV 4.9
Upgrade to SCV 5.0 and SCV 6.0
SCV 4.8
Upgrade to SCV 4.9 and SCV 5.0
SCV 4.7
Upgrade to SCV 4.8 and SCV 4.9
SCV 4.6
Upgrade to SCV 4.7 and SCV 4.8
Tip Backup the SnapCenter Plug-in for VMware vSphere OVA before starting an upgrade.
Note Switching your network configuration from static to DHCP is not supported.
For the latest information about supported versions, refer to NetApp Interoperability Matrix Tool (IMT).
Steps
  1. Prepare for the upgrade by disabling SnapCenter Plug-in for VMware vSphere.
    1. Log in to the SnapCenter Plug-in for VMware vSphere management user interface.
      The IP address is displayed when you deploy the SnapCenter Plug-in for VMware vSphere.
    2. Select Configuration in the left navigation pane, and then select the Service option in the Plug-in Details section to disable the plug-in.
  2. Download the upgrade .iso file.
    1. Log in to the NetApp Support site.
    2. From the list of products, select SnapCenter Plug-in for VMware vSphere, then select the DOWNLOAD LATEST RELEASE button.
    3. Download the SnapCenter Plug-in for VMware vSphere upgrade .iso file to any location.
  3. Install the upgrade.
    1. In your browser, navigate to the VMware vSphere vCenter.
    2. On the vCenter user interface, select vSphere client (HTML).
    3. Log in to the VMware vCenter Single Sign-On page.
    4. On the navigator pane, select the VM that you want to upgrade and then select the Summary tab.
    5. On the Related Objects pane, select on any datastore in the list and then select the Summary tab.
    6. On the Files tab for the selected datastore, select on any folder in the list, and then select Upload files.
    7. On the upload pop-up screen, navigate to the location where you downloaded the .iso file, then select on the .iso file image, and then select Open.
      The file is uploaded to the datastore.
    8. Navigate back to VM that you want to upgrade, and select the Summary tab.
      In the VM Hardware pane, in the CD/DVD field, the value should be “Disconnected”.
    9. Select the connection icon in the CD/DVD field and select Connect to CD/DVD image on a datastore.
      vCenter UI
    10. In the wizard, do the following:
      1. In the Datastores column, select the datastore where you uploaded the .iso file.
      2. In the Contents column, navigate to the .iso file you uploaded, make sure “ISO image” is selected in the File Type field, and then select OK.
        Wait until the field shows the “Connected” status.
    11. Log onto the Maintenance console by accessing the Summary tab of the virtual appliance and then select the green run arrow to start the maintenance console.
    12. Enter 2 for System Configuration, then enter 8 for Upgrade.
    13. Enter y to continue and start the upgrade.
