Restore backups from renamed storage using the SCV
When the storage is renamed, workflows using backups taken before the rename used to fail. With the introduction of the rename backup feature, which is exclusively accessible through REST API, it is now possible to use the backups that were taken prior to the storage renaming. The workflow and usage of the REST API are described below.
ASA r2 storage system does not support _recent snapshot naming feature. |
Add or update the new storage connection, ensuring that the new Cluster or SVM name is reflected in SCV.
Restart the service to refresh the caches as described in the KB article: SCV backups fail after SVM rename
Create a new backup.
Use the backup details to find the old and new storage names.
In the Backups screen of the vSphere client, select the backup to see its details.
Access Swagger from the URL:
https://<SCV-IP>:8144/api/swagger-ui/index.htmlUse the following API to rename the storage:
PATCH
/4.1/storage-systemExample:
"existingSVM": {
"name": "string"
"newSVM": {
"name": "string"
}Response:
"statusMessage": "OK",
"statusCode": 200,
"responseMessage": [
"Storage system renamed successfully."
}After running this API you will be able to run all the workflows including the restore operation from the old backup.
